Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Kenmore Dishwasher installation
New Kenmore dishwasher, with legs unscrewed and removed and back wheels at highest setting, measured 33 1/2 inches high. Opening under counter measures 33 1/2. Installers say it won't fit. Any solutions? Thanks
    Sniper:
  • 68 Answers
It sounds like you either replaced your floor or your counter tops/cabinets.
Your 2 options are to:
  1. Remove the flooring, (i.e. tile) to the toe kick of the cabinet allowing the dishwasher to drop in. I recommend reinstalling the legs on the dishwasher if you have the room after removing the flooring.
  2. Trimming the cabinet/counter top. This is assuming that you have room to trim.
  3. Shimming the counter top up to raise the countertop up 1/4" to 3/8".
I recommend having the legs on the dishwasher. This helps in leveling. Be sure to attach the dishwasher to the counter top. This will keep the dishwasher from moving.
Please rate this solution
Posted on Aug 19, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Posted on Mar 11, 2008
How do i adjust the height as no legs attached to back of dishwasher
The feet come all installed they are under the front of the dishwasher, you need to remove the bottom kick plate and you will find them
Jan 09, 2016 | Whirlpool ADG8410FD 597 mm Black Built-In...
My dishwasher was installed, then wood floors added and now the height is only 33 inches. How do I get the old one out and find a new dishwasher that is 33-33 1/4 inches tall?
Take a sawzall and cut the front legs, pull the dishwasher out until the back legs hit the new wood floor and then cut those legs from the sides. It's your old dishwasher anyway, so who cares if the legs are cut off?
Aug 13, 2011 | Dishwashers
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
Need to replace this unit ASAP and am having issue finding one that will fit. My R.O. is exactly 34". The existing unit shown was OK because of the 33 - 1/2. Recommendations?
all dish wahers are the same height
the differance your seeing is that
is has been adjusted to fit your cabinet height
with the adjustable legs
all units can be raised by srewing down the legs
and back levelers
make sure when you do your cabinet measurements you take this into account
Oct 26, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
How do i change the heating element of my kenmore dishwasher?
take the toe kick off
there in the middle about an inch back
you will see two element nuts
unscrew them pull the element up
put the gaskets on the new element
put in in place and screw it back down with the nuts
Oct 03, 2009 | Dishwashers
Raising back legs on Ariston LL65SNA
The red nut driver plugs are located on the front of the dishwasher under the toe kick. The reason for this is that you need to slide the dishwasher in place before you raise the legs, otherwise you will probably bend or break the adjusting legs. You can raise the legs a little if you need to clear the water and power lines, but be careful when sliding the unit in. If you use a socket wrench with a long extension on the driver it will be much easier.
Jan 10, 2009 | Ariston Technologies LL65 Built-in...
Dishwasher opening
You can remove the feet from the bottom of the dishwasher
Jan 05, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Jan 05, 2009 | Dishwashers
Whirlpool dishwasher installation
FOUND IT!!!!!
There is a white plastic screw in front of the dishwasher to estend the back leg!!!!!
Whirpool people are crazy!!!!
Max
Aug 17, 2008 | Dishwashers
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
391 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
