Question about Kenmore 24032\24036 Top Load Washer
Washer overlfow I just purchased a used Kenmore it says MOD: 110 20702 991 & it also says 70 series on the panel. It is seems to have an overflow problem but there is no water leaking from the bottom of it. If I knew what the problem was, I could probably find a buddy to come fix it for me. Any suggestions???
    Sergeant:
  • 288 Answers
How bad is the water overflow. A little puddle on the floor, or it will fill up to the top and be a waterfall until you shut it off?
Posted on Mar 13, 2008
Kenmore washer mod.11024642300 washer over flows
If it overflows while filling, the level sensor may have failed.
Feb 01, 2018 | Kenmore Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
How do you remove the back of the Kenmore 90 Series Washing Machine? I am troubleshooting the problem that my machine doesn't stop filling and overflows.
Most Kenmore washers are made by Whirlpool. If yours is this page will help http://www.appliance-repair-it.com/Whirlpool-washer-disassembly.html
Note that I cannot know without the full model number but follow that page and if it doesn't seem right your washer may not be Whirlpool made.
Sep 24, 2010 | Kenmore 24032\24036 Top Load Washer
Drain standpipe overlfows on eshausting water
The pipe is clogged and may need to be replaced or cleaned out. Over time the pipe will get a build up of dirt and soap that you can't get out.
May 19, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series model 20842990
You answered your own question. It was in between the line and now it's fine.
May 23, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
158 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
