Question about Dryers
Dryer door clip
We have a Gallery series, model # GLEQ2152ES, dryer . . . the dryer door clip repeatedly pops out. We are able to do a temporary fix until the clothes hit the door. Please let me know a permanent solution for this problem.
Thank you!
  • Dryers Master
  • 2,651 Answers
Try replacing both the catch and strike , call local part wharehouse or order online, real easy to install just pop them in
131658800 - CATCH-DOOR
5303207102 - STRIKE
Posted on Mar 11, 2008
Dryer gallery series e68
Good Morning Friend,
I understand you want to know how to replace the board on your Frigidaire dryer, model# GLEQ2152ES, due to receiving an E68 code. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to replace the board with ease. Hope this is helpful.
-Best Regards-
Jun 27, 2014 | Frigidaire Dryers
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't start
maybe the dry door switch or the reset button on the motor. if you here like a click noise when you push the start button then its the reset. if not then more then likely it is the switch, which means either way the front panel has to come off, screws are located inside dryer door, the top corners are clipped from the inside so a flat tip screw driver will pop the corners, then disconnect switch, if it is the switch remove switch and tape wire together, put front panel on with top clips, plug in and push start drum should turn. get new switch.the reset buttons are on the motor and when you push the reset it will click. Hope this helped Tim
Sep 23, 2010 | Frigidaire GLEQ2152ES Electric Dryer
How do I install the shoe rack in my frigidaire gallery series dryer?
You have to remove the lint filter and the part of the shoe rack that sticks out then fits into the slot when the lint filter would sit.
Jun 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Need to remove the front
there are two screws on the back of the lid take those off then slide the lid off remove the screws that hold down the control the the screws on the inside of the cabinet that hold the front panel in place once removed the panl will pop off
Sep 09, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
open door spin drum and close door and start unit your motor has a dead spot
Sep 20, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
489 people viewed this question
Top Dryers Experts
