Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP dv2000 when the computer boots up it shows a black screen saying Operating system not found. What can I do to try to fix this issue? the hard drive or something may have gotten stirred
  • 3,587 Answers
Stirred? I'd say it's lost in the'll need to boot from installation cd, and possibly reformat your drive. Hope you got backup...
Posted on Mar 11, 2008
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
NF110 Netbook shows black screen and at top says 'operating system not found' Can you help?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. . Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 18, 2012 | Computers & Internet
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Computers & Internet
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
Whenever I start my HP laptop, a black screen loads and it says " Boot device not found, please install an operating system on your hard disk". I have no clue how to fix this.
Sounds like the hard drive has been formatted and you need to install windows on it. Was it working before or did you just buy it second hand?
Screen says Operating System not found.
Either the OS installation was damaged to where the computer cannot recognize it or the hard drive is damaged and needs replacement. You could try and use the recovery disc or operating system disc that came with the computer to try and repair or re-install the OS. If the installation fails then try taking out the hard drive and installing it in another computer to see if it is working or not. You should be able to re-partition and format the drive. If not replace the drive, If the drive tests good then it might be a hardware issue with the motherboard for the laptop.
Nov 07, 2009 | HP Pavilion dv6000z Notebook
My HP dv2000 will not boot the screen says BOOTMGR is missing
you need the Operating System Disc or possibly boot to your recovery partition.. try holding F10 or F11 Upon boot to take you to the recovery screen if it is still there...
Nov 20, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
Operating system not found on my laptop
ok i have had this problem.. (my computer would show the loading screen with all of the commands at the bottom. after this it would not boot up, but show a message on a black screen saying "operating system not found")
I completly tore down the laptop and making sure i had no issues with anything. so here is what i did that is simple and ended up solving the issues 3 times in a row.
1. take the cover off for the hard drive on the bottom of the laptop ( shows 3 very small disks beside each screw)
2. grab the clear strip that is on the hard drive and pull out the hard drive. ( blow out where it connects on the right side if dirty)
3. Reconnect the hard drive this will reset it.
4. Make sure to change back the processes to defaults when the computer starts back up.. If you fail to do so you will have to repeat the process each time you turn off the computer.
(This will only work if you messed up some settings while having the computer on, and not if you have faulty parts.)
for me i ctrl alt deleted and accidentally ended some important processes..
any other issues just email me at i will try to help you out. =D
Apr 03, 2008 | Compaq Presario 1692 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
