WASHING MACHINE YOU JUST ANSWERED MY QUSTION ABOUT NOISE FROM A WASHING MACHINE AND YOU SUGGESTED IT NEEDS TO BE LEVELED a FRIEND OF MINE IS COMING TO DO THAT MY OTHER QUESTION IS THIS THE MACHINE IN QUESTION WAS PURCHASED USED YET i SAW IT WORK PRIOR TO BUYING IT WHE WE TRANSPORTED IT WE LAID IT DOWN BECAUSE IT WOULD NOT FIT STANDING UP AND 3 REPAIR PLACES SAID i COULD dID I INFACT BRAKE THE MACHINE BY LAYING IT DOWN COULD THAT BE THEE PROBLEM WITH THE NOISE THANKS
    Problem Solver:
  • 6 Answers
That could very well be the cause of your noise. You will need to remove the back cover of the machine to look inside and see if anything is out of position. Some machines have a concrete block used as a counter weight for the belt drive. You may need to move it back into its holder. The tub could also be out of center. You can recenter it by moving the tub around from the top by the agitator. Make sure all the belts are in the pulleys if it is a belt drive. The back panel should come off by taking out a few screws or bolts.
Posted on Mar 11, 2008
Why is that machine so noisy, can you suggest another model less noisy?
Annette, your machine may not be leveled correctly, causing excess vibration and noise, have it checked before getting new. below are links to advertised quieter models.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Washers Dryers Washers
Matching washers and dryers quiet enough for the main floor
6 Best Washing Machines in 2016 Buying Guide
Washing Machines
Feb 15, 2016 | Washing Machines
Sears Mod.110.29852991 washing machine makes knocking noise in spin cycle
sounds like unbalanced load or machine needs to be leveled on floor
Feb 05, 2015 | Washing Machines
Sounds like a jet plane taking off when it spins, I think I got in 2003 Also the top of the agitator wont stay on
Has it always sounded like a jet plane? If it has. Then who installed your new washing machine didn't disengaged the two counter weight inside the washing machine. There two concert block or plastic block inside the washing machine. Each block is attached to one end of counter blanching bar which has some spring attached to them. During manufacturing these weights are tied down for shipment. During installation the ties are removed then the washing machine can be leveled.
Counter weights are used to off set the uneven load in the tub. That way the washing will not start walking in the house. Side load washing machine use a plastic donut the fits around the drum and it fill with fluid for counter weight.
Now the cap of the agitator, it broken. The locking tabs are broke off. needs to replace. I hope you said the top of the agitator and not the agitator is coming out. If it is, you got major problems. stewbison
Aug 20, 2011 | Amana Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Washing machine rumbles when spinning
it needs to be leveled. most units are self leveling meaning they sit evenly. if yours in on uneven ground make sure you get it onto a flatter spot. should help.
Aug 23, 2009 | General Electric WSXH208H Front Load...
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washing machine walks while spinning
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. in washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 13, 2008 | Maytag Neptune Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
