Question about Mintek DTV-263 26 in. LCD Television
Mintek Fix Ryan I am following your fix for the Mintek LCD's which are frozen in the DVD mode. Mine is the DTV-265-D model and I would like to follow the procedure of attaching the component wires directly to the component input terminal on the motherboard. Problem is, on this model, there are only 2 non-flat strands and 3 flat strands coming off the component input. Your instructions said that there should be 3 of each and that the input wires are to be connected to the non-flat strands and the grounds to the flat strands. Each of the flat strands on the right & left are long while the flat strand in the center is short. One of the non-flat strands in directly between the left and middle flat strand. From this arrangement it would seem logical that the three input wires should be attached to the the corresponding flat strands and the 2 ground wires from these input wires should both be attached the non-flat strand the is between them while the 3rd input wire and ground wire should be attached to the remaining flat strand and non-flat strand. Are you sure that the input wires must be attached the the non-flat strands? If so how should this be done given the set-up I described. I'll look for your reply here on the site. Thanks PS: If your fix works it will be a god send to all those who have these frozen Mintek units and they are legion!
    Problem Solver:
  • 11 Answers
It may be a little different on the 26" model. It's been several months since I did the repair so my memory is a little fuzzy. It sounds like the non flat strands are a common ground and the flat ones are the hot wires. The best thing to do would be to take a multimeter and test for continuity on the center of the RCA jack and the flat strand of metal. If you get a reading, that is where the input wire should be soldered. More than likely you're correct and you should proceed as you found logical.
All you're really doing is making a new connection for the component input on the back of the TV. So just make sure that each hot wire from the DVD player will be on the strand of metal that corresponds with the hot wire from the component RCA jack, which is the center part of the jack, not the outer metal sleeve. In theory you could just attach all of the grounds from the DVD player to any metal part of the TV; I do not know if this will work however because the set might have a failsafe on the motherboard, not allowing video pass through when grounds are not detected.
I hope this helps! And please let me know if you get it working or have any other issues.
Ryan
Posted on Mar 11, 2008
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Mintek tv/dvd combo dvd is stuck, volume is stuck, chanel is stuck
The model DTV-263/265 has this common problem, the main board will have to be replaced.
Oct 30, 2009 | Mintek DTV-263 26 in. LCD Television
Mintek -dtv-265-d stuck in DVD mode
These units have had a failure in either logic board or the main board. The only way to repair these units is to get replacement boards and see if this repairs the problem. You can try to source these parts at e-bay. Use the search engine, plug in the make of you television model number, and part number of the board you think you need for the repair.The search engine will bring up all available parts for you.You can also try this website for parts. http://www.discount-merchant.com/SearchResults.asp?Cat=&Search=PCB&RefineBy_Manufacturer=MINTEK I hope this information is of some help to you with your problem.
Mar 15, 2009 | Mintek DTV-265-D 26 in. LCD TV
I have mintek dtv 265-d lcd 26in
Have tried the remote, most new tvs have a control panel lock that can accidently be activated, it usually takes the remote to undo the lock.
Let ne know.
lone99star
Jan 08, 2009 | Mintek DTV-263 26 in. LCD Television
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
I need a power cord
If it's the same as the DTV-265 26" LCD/DVD, then it is the same as a power cord for any standard PC Tower, or PC Monitor. <br><br> I bought one off ebay for $6. Or just go to your local computer store.
Feb 18, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-373-D Remote code
As far as I know, no regular universal remote will work with the mintek TV/DVD's.
I have heard that the "Kameleon" remote, from radioshack works with them.
I had the same problem, so I ordered a replacement original remote from ebay for $20. It was the RC-600 for mine (DTV-265 26" LCD/DVD)
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd=1&item=360029014984&ssPageName=STRK:MEWN:IT&ih=023
Feb 11, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Mintek 26 lcd hdtv, model DTV 265D
Have Mintek DTV-265-D that is frozen. Any suggestion to correct this problem?
Oct 20, 2007 | Mintek DTV-263 26 in. LCD Television
Stuck DVD
I have a Mintek DTV-265-D which is frozen and neither the buttons on the set nor remote will work. Anyone know how it get it working?
Sep 02, 2007 | Mintek DTV-233 23 in. TV/DVD Combo
Mintek DTV-263 26 in. LCD Television... Problem:
I suggest you go to their website at: http://www.mintekdigital.com/user_man.asp The DTV263 is not available online, but the DTV323 is there and this should be the 32" version of the same set. Download the manual for the 32" version.
Aug 20, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-263 26 in. LCD Television Logo
148 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
