Question about GE Spacemaker JVM1640SJ Microwave Oven
Hole in film on interior door
Spacemaker has a hole in microwave door film about 1/8 in. Can I just replace the film or patch the hole???
Thanks kenny
  • 492 Answers
I would consider buying a microwave in the near future, or at least not standing there watching your food cook the whole time. The film works with the grid with the small holes in it to eliminate the microwave radiation that the unit produces. A hole in this film compromises the intergrity of the unit. Essentially it would be like tryring to create a dark room with no light and having a hole in your covering, creating an escape for the light to get through.
Posted on Mar 11, 2008
    President:
  • GE Master
  • 2,651 Answers
Wouldnt be concerned about hole in the film strictly cosmetic!film wouldnt be available youd need t repalce door and thats just not feasable
Cannot access screw for lower part of handle blocked by interior assembly
The inside of the door must come apart. Be careful that screen inside the door is actually a choke to keep the microwave radiation in. Make sure that you replace each and every screw and everything else just as you took it apart.
Good luck
Dec 13, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace the sealing plastic film inside microwave door?
you must read your instruction coming with the material, or call them or go ONLINE via chat for the support.
God bless you
Nov 26, 2013 | Samsung SMH9187 Microwave Oven
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
The film on the inside of the microwave oven door has bubbled & is raised off the glass. Is it safe to use.
No, that must be patched or replaced. It's critical.
The film protects the door screen from getting food, grease or moisture in it, which can lead to corrosion and arcing.
The screen prevents microwave energy leakage, which can cause arcing and fire.
If the bad spot is not too big, you can cut it away and clean it squeaky clean and patch it with clear packing tape.
If it's too bad to patch, you'll have to see if you can get new film, or if you need to order the inner door panel or whole door.
You can locate Sanyo manuals, part distributors and authorized servicers here.
You can find Sanyo UK microwave owner's manuals here. You can find Sanyo UK support, parts and authorized servicers here.
Oct 29, 2009 | Sanyo Microwave Ovens
Condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The mesh screen on the inside door has a hole in it..
would suggest replacing door for safety purposes only," it could be fine as far as resisting waves",but never sure for how long or if it realy is. An old saying makes sense," Better safe than sorry".
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,092 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
