Whirlpool washer i just purchased a used whirlpool washer. I was present when it was used at the house and it worked great and quiet. We transported it to our house in a suv on its side I was told by appliance stores this would be okay for an hour. once home plugged it in attached hoses and drain and the machine is so loud on spin it sounds like it is going to blow up did i brake it by transporting it on its side thanks
    President:
  • Washing Mach... Master
  • 2,651 Answers
Im going to assume its a front loader. try opening the access panel by removing 3 screws along bottom front of unit. give a look inside, there should be 4 suspension/shock absorbers holding drum form shifting.If disconnected the just "snap"into place with quarter turn into holder.while under there the pump is located right there in front, open the "button trap" front of pump see if perhaps theres something inside pump housing making noise
Posted on Mar 11, 2008
Where can i find transport bolts for Whirlpool Duet washer
Whirlpool has a part number for those shipping bolts,its W10289554A it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wirpool stylemaster907675A got it from my mom she said worked great, first load the water will not turn off, keeps running out the overflow and onto the floor
That sound like one of a couple things,espically if it got moved from yoiur Mom's house to yours check firstly if the hose circled in red on this picture accidently got pulled off in transport.oldtech2332_1.jpg
If that is ok the water inlet valve where the rubber fil hoses attach that attatch to the blue thing on the back of washer is sticking open.IF that hose in the picture is in place its probaly that water inlet valve and it would be replaced.The part # for that is 285805 it could be purchased at your local appliance parts store or online at;
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
This video http://www.youtube.com/watch?v=Puq8jWMY9Iw will show you how to take apart the washer to check that hose or replace the water inlet valve which ever it turns out to be.
Gene
Aug 14, 2011 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
During the final spin cycle, our front loading whirlpool is making a really loud noise - it sounds like a train is going through the house. It is in the basement on a concrete floor.
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dishwasher quiet #1
Have you figured your dishwasher problem out yet? In my Whirlpool, that tube doesn't fit on the wash column, it just snaps on to the lower rack, right above the washer column black rubber gasket... hope this helps!!!
Sep 02, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Dependably Quiet Model #DWU7400ABE
they must be treating the water differently now. go to www.dishwasherfilter.com. there filter should solve your problem.
Jul 31, 2008 | Dishwashers
Whirlpool washer noise
moving it on side might empty gearcase oil, any yellowish oil drippin gout of anywhere? hard to tell about hte metal movig around, its quite normal for machines to move around quite a bit on the inside
Mar 11, 2008 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
