Question about GoVideo Go Video DVD/VCR Combo
When I insert a dvd I get "BAD" dvd error...does this mean the unit is bad, or can I reset something, or will a cleaner work? Thanx
  • boiesd Mar 17, 2008
    Mine says disc dsc err when i put a dvd in. How can i fix this problem? I know that the disc is good because I've tried several that i know are good.
  • 11 Answers
Does this happen with more than one disc? This seems to be a common problem with this unit. Have you tried contacting the company?
Go Video Customer Service
2124 Carr Street
St. Louis, MO 63106
T: 314.657.2366
F: 314.588.1805
Posted on Mar 22, 2008
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
DVD will not load or play. Just keeps saying loading over and over
This probably means that your DVD player has a dirty lens or a tracking problem or both. If the DVD player has a tray, you can try putting an optical disc lens cleaner into the unit. (Slot-loading DVD units may not properly accept or eject the disc. So don't try a cleaning disc in that type of unit.)
Since most DVD players are cheap, it's usually better to replace the unit if the tracking is bad. Similarly, if a lens cleaner does not work, replace the unit. If the player is under warranty, contact the manufacturer.
I hope this helps.
Sep 29, 2013 | Toshiba Se-r0047 Remote Control
My niece's dvd player is having a no disc error. I can't even get a lens cleaner dvd to work.
Hello, Thanks for the opportunity to help.
When you said disc cleaner did not work what comes in our minds is a bad laser, or laser pico fuse went out on it.
Regularly people would just purchase a new unit at this point. No disc could also mean the unit is not spinning the disc fast enough to be able to be read.
If there is a warren ty on it witch I doubt you might want to have it honored as the last step.
1. Check and see if the disc is spinning (if not its the motor)
There are not many parts for this unit as disney contracted out there manufacturing to some knuckle head in china. Parts will not be abundant here.
If the lens cleaner did not work chances are the unit is past its prime.
Thanks for using
Jan 28, 2011 | Disney Princess DVD Player
Error with Dual Head Unit
your lazor might be dirty or bad. try a disk cleaner.
Aug 19, 2009 | Car Audio & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
DVD Player Displays 'Disc Error'
try a cleaner disk, if that doesnt work, junk it and buy something better than this dvd players have a habit of not working very long....
Mar 31, 2008 | Durabrand DVD-1002 DVD Player
Xbox 360
Listen to your dvd drive to see if it spins up or not when you put the disk in. If it does spin normally then you will be need a replacement laser.
If it does not spin correctly. The motor is stuck, sometimes if you open out the tray and stick something into the drive and give it a spin it will free the drive.
Check out this link if you have the Hitachi dvd in your xbox360
Mar 18, 2008 | Microsoft Xbox 360 Console
GoVideo Go Video DVD/VCR Combo Logo
53 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
