Question about Superstar SS-121 120-Channels Base CB Radio
Instead of an amplified mike
If I do not want to use an amplified mike, where inside the radio do I find the pods to adjust?/
  • 46 Answers
Hello...i,m in contact with a group of cb-ers outside u.s. and waiting for response...just hold on ..have a good day...Ron
Posted on Mar 12, 2008
  • lars ahlsen Mar 15, 2008
    Hello...sorry for the delay..but the most i can do is to refere you to the following site, they can help you...via google...search for ..."radiomods.co.nz"..and look through their info.......good luck ... Ron
Radio plays fine no music comes out on cd, aux, or I pod mode radio sounds great any ideas
Are you using an ampilfier? If so, it sounds like you are using the power antenna remote, (blue wire) instead of the amplifier remote (blue/white) to turn the amp on. The power antenna remote turns off when leaving tuner mode, turning the amp off.
May 30, 2015 | Car Audio & Video
How do i set the dead key on a cobra 29 ltd
ok .ther is no pot per say ,But if you are wanting to turn the dead key down you can adjust the choke at L14 . that will bring up or down ,but only by 2 watts .
Jan 31, 2014 | Cobra 29 LTD CB Radio
How do I turn up key and adjust modulation on cobra85 dynascan base CB?
The best way to solve this problem is to find a power mike for the radio, it will bring the modulation up to 100% instead of the 25-30% that you are currently working with and your carrier wave will have a lot more punch. Ham radio shows are worth checking to find what is needed, or second hand store may be another option.
Feb 29, 2012 | Audio Players & Recorders
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Mar 21, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
My ilive ipod radio does not want to charge my i=pod
I had the same problem...but what I did was plug it in instead of using the batteries and it started charging. Maybe this will help.
Jun 13, 2009 | Apple iLive IBCD3816DT Portable 2.1...
Galaxy DX99V
The RK56 was a good mike until Telex bought out Turner many years ago. Now the audio output is lower than it used to be & it's not a compatibility issue as Galaxy radios have microphone amplifier circuits similar to most other CB & 10-Meter radios. You'd have been better off buying an Astatic 636L or even a generic noise-cancelling mike instead. The only thing I can recommend is to hold the mike on your cheek, close to but not directly in front of your mouth, with the grille facing it & speak in a louder than usual voice.
Sep 24, 2008 | Radio Communications
Grantxl
Either the mike or cable is bad or you have a problem in the transmit speech amplifier or modulator.
Jul 12, 2008 | Uniden GRANTLT 40-Channels Base CB Radio
Amp problems
The head unit probably has 2 control wires. One has 12v when the signal source is the tuner. When you switch to the other sources, the antenna is not needed so the output to that wire is switched off (so the power antenna will go down).
Look for a wire marked amp control or something similar. It will have 12v output any time the head unit is on. Use that one to control your amplifiers.
Apr 04, 2008 | Visonik V117SX Car Audio Amplifier
Superstar 121 ranger radio
Hello...the best way without making internal adjustments...is to use an amplifier microphone...maybe a turner style mike hand or base...there is just a connector soldeing job and is usally an instruction for what pins to connect for your radio...it is often no adjustment internally in your radio that is good becauie it can give the result of splatter and over modulation...good luck Ron
Mar 11, 2008 | Superstar SS-121 120-Channels Base CB...
Radio Communications Logo
70 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
