Question about Whirlpool GEW9250P Electric Dryer
Whirlpool dryer When i push the start button it just beeps and the sensing light flashes and the dryer will not start any suggestions?
  • 3 more comments
  • premium Mar 11, 2008
    I tried the switch door still nothing,when you shut the door and push the start button it beeps then you hear a click then the panel just flashes and the dryer does not start any more suggestions?
    When I shut the door and push start it beeps then you here a click and the panel just flashes and it does not start? Checked the door button seems to be fine any other suggestions?
  • chabbii Jun 22, 2008
    Yes my dryer does all the sensing and beeping but it does not start. It does not tumble! But you can right away feel it getting warm, it just doesn't turn and there is no sign the motor is starting, there is no other noise.
  • Anonymous Mar 16, 2014
    My Whirlpool gas dryer doesn't start when I push the start button
    the minute display lights up with the number of minutes, but when i push the start button it flashes and beeps; but won't start.
My Whirlpool Ultimate Care II with Accudry was stopping in the middle of a cycle as if the clothes were already done and dry but they were not. Even the cycle buzzer would come off in the middle of a cycle and stopped.
I fixed.
So if you have same problem it seems to be the sensors inside the dryer drum. They "think" the clothing is dry when it is still "moistured".
To fix it just clean those two metal sensors with a soft abrasive. I used a very fine sand paper and cleaned not only the exposed metal conductors. the ones that touch the cothing, but also in between the two conductors that black plastic base where the two metal contacs sit on, clean it. brused, sand it, in between so nothing will create a short between them.
Now it works fine again. I was ready to call my extended warranty.
I hope this help some one.
Posted on Oct 10, 2011
The fuse may be blown. It is located to the left of the vent hose and has two blue wires with push on tabs. Check for continuity between tabs. DISCONNECT POWER FIRST !!!!
Posted on Sep 14, 2008
1) sounds like that accudry sensor needs checking. If the accudry sensor (the back box with the two silver trips in it under the lint filter) does not sense wet garment it coul cause the dry to start and then cut off or not start at all. did you try using a cycle that does not sense the load you are dying. 2) the mother board of the dry may need chnaging depening on your dryer. if your dryer is like the cabrio, duet or the senseon dryer then it could be a motherboard problem.
Posted on May 20, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Posted on Mar 11, 2008
Whirlpool GEW9869K beeps when plugged in and lights flash
pf error is power fault most of the time. circuit board maybe! lots of things to test... but main circuit board is my guess.
Aug 31, 2012 | Whirlpool GEW9868K Electric Dryer
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Dryers
Can not get my dryer to turn on
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Whirlpool dryer,duet
check the door switch for operation, if the machinr thinks the door not closed == no operation
Jan 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
1,137 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
