Upgrade motherboard? I want to upgrade my HP a1226n motherboard and cpu which chipsets can i use
  • 27 Answers
Hello Keith,
The present Motherboard in your computer is Asus A8AE-LE. It has a lot of upgradign options.
It will support the Following CPUs.
Up to AMD Athlon64 X2 4800+
Up to AMD Athlon64 4000+
Up to AMD Sempron 3200+
Also, it has the following memory specifiations.
Memory Installed 1 GB (2 x 512)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
Speed supported PC-3200 MB/sec
Type 184 pin, DDR SDRAM
DIMM slots Four
Open DIMM slots Two
And the PC has a PCI Express x16 slot you can install a high end Video Card along with a power supply upgrade.
So before you go ahead with replacing the motherboard I would recommend you to consider these options as we can cut down the cost to a greater extend and having the same iprovement on performance.
If you wish to upgrade the motherboard you can use any motherboard having ATX form factor [9.6 in X 9.6 in] in the computer. The CPUs should be selected according to the motherboard you have chosen.
Hope this helps
Pat
Posted on Mar 11, 2008
Cpu upgrade
A) http://www.fixya.com/support/t18040647-cpu_upgrade
B) http://www.fixya.com/support/t18040647-cpu_upgrade
(Last time I looked, this was the world's largest product support website, and there ARE technicians from AROUND the world; on here!!!!!!!! Do we count as an 'IT techie'? ........Lol!)
In all three of your posts, not once has the laptop manufacturer name, and model number been stated.
Processor (CPU) support depends on;
A) What processor socket is on the motherboard?
B) What motherboard chipset does the motherboard use?
C) What is the processor that is installed now?
With these parameters known, THEN you can think about CPU (Processor) upgrade.
1) CPU (Processor) has to FIT, the processor socket being used.
THIS, is also IF the motherboard HAS a processor socket; and is NOT soldered directly to the motherboard.
2) The motherboard chipset supports the Processor (CPU)
It has to be known if the motherboard chipset will support, the CPU (Processor) that you want to upgrade to.
For older computers the motherboard chipset consists of;
A) Northbridge chip
2) Southbridge chip
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
With this technology the Northbridge chip, of the motherboard chipset; is what determines Processor (CPU) support.
Newer technology, such as used per se by the Intel Core i processors, does NOT use a Northbridge chip.
3) Looking at the existing Processor now, you can determine;
A) Voltage Range: What voltage range does the exisiting Processor use now?
Does the upgrade Processor also fall within this Voltage Range?
B) Core technology, and architecture:
Example:
Existing Processor uses the Conroe Core technology, and the 90nm architecture. (NanoMeter)
Does the upgrade Processor also use the same Core technology, and architecture?
If not is there a BIOS upgrade available?
(The motherboard chipset also comes into play again, here)
Enough of this generic prattle.........
Post the laptop manufacturer name, and model number.
Then I, or someone else can give you the facts; and not generic information.
Post back in a Comment.
Regards,
joecoolvette
http://www.hardwaresecrets.com/article/535
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
May 05, 2013 | Computers & Internet
I want to upgrade my HP pavillion a1220n pentium 4 by change motherboard.Can you show me the way?
Hi,if your planning to change motherboard for your CPU,make it sure that the board your using is the same chipset so that you will not reformat on it,or the best way for that is to upgrade your computer into DUAL CORE..thank
Sep 02, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
I want to upgrade my CPU capacity from 1.2 GHZ and want to know my motherboard so much support??? my motherboard is GA-8IDX (845 chipset)
If you go to CPU-Upgrade.com, you can see all of the different processors that are compatible with your motherboard:
http://www.cpu-upgrade.com/mb-Gigabyte/GA-8IDX.html
The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
Feb 13, 2011 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Update CPU in HP Laptop
It is impossible to upgrade a CPU for a laptop.
That is the bad side of laptops, you are stuck with the same processor which can not be upgraded
Dec 30, 2009 | HP Pavilion dv1000 Notebook
I don't have a problem. I just need to know what kind of motherboard my PC has. its a HP Pavilion dv7.1135nr . thank you
I am guessing you are asking because you want to upgrade it?
If not, download this free program, and it will tell you all the info you want to know about your computer: CPU-Z here: http://www.cpuid.com/cpuz.php
Okay, well you have an AMD based DV7,
The 780G chipset is among the latest from AMD. That chipset supports the Turion ultra processors.
Your system may be running slow because your cpu is running at 500MHz instead of 2Ghz.
You can upgrade your processor to any RM/ZM/QL turion processor.
The processor in your system is socket S1
Your current cpu is a RM-70, 2.0Ghz dual core, 1mb L2, and 31 watt TDP
The RM-74 would be an upgrade to 2.2Ghz dual core, 1mb L2, and 35 watt TDP
However your best upgrade at the moment is the ZM-86,
The ZM-86 is 2.4Ghz Dual core, 2mb L2, and 35 watt TDP
The ZM processors are going for around $200 on ebay
I do not think the 400MHz upgrade is going to be worth $200.
Jun 25, 2009 | Computers & Internet
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
Jun 23, 2009 | HP Pavilion dv1000 Notebook
Pentium 4 3.4 GHz S478 800 FSB cpu compatibility?
motherboard does not support this UPGRADE of processor, Regards
Apr 08, 2009 | Computers & Internet
Upgrading System.
http://ark.intel.com/chipset.aspx?familyID=28994 hello, i would replace the 1.8g cpu- go 2.2 or higher,then do another gig of memory. this will make it very fast. compared to now. check e-bay for cpu deals.(as these cpu's are still a little costly new) i got one-as an upgrade for my intel 2.6 965 chipset a few months ago, now at 3.2g. nice upgrade no problems. i hope this helps you, good luck! if you need help post again.
Mar 10, 2009 | Intel Computers & Internet
I have 2.6 celeron processor with intel 865 motherboard i am up grade tell us who is processor best
on mb with intel 865 the bigest CPU is pentium 4 @ 3GHz. socket 478
however your MB might require to update microcode for the new CPU.
one more thing: this chipset Intel 865 is obsolete, and intel does not manufacture this cpu type anymore.
Feb 22, 2009 | HP Celeron A , 2.6 GHz (DL458AV) Processor...
Cpu upgrade
You can upgrade your pc to intel chipset original motherboard...and do it to intel core 2 duo processor. if u want to upgrade ur ram then go for 1GB ram... and 250 GB hard disk and finally go for pentium-IV and dvd writter... and use microsoft mouse and keyboard bcoz it does not require driver to be installed
Oct 01, 2007 | IBM I System Board (61H2600) Motherboard
Computers & Internet Logo
360 people viewed this question
David Payne
David Payne
