Question about Whirlpool GD5SHAX Side by Side Refrigerator
No ice I have a Whirlpool Top-Mount Refrigerator that stopped making ice. Is there a common solution to the problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
Well its gonna be 1 of onlya few things. bad water valve, bad ice maker . glitch nad something froze up .fi you pop off the cover to the ice maker itself( white cover), teres abuncha test poits rightthers as well a tech sheet behind the kickplate, explaining which test point to check. before that just kinda put your hand inside ice maker andn see if ice is just jammed preventing unit from cycling
Posted on Mar 11, 2008
My automatic icemaker has suddenly stopped making ice. Can you suggest the possible problem.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 24, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
We have a GE side-by-side refrigerator. Ice maker has stopped making ice; however, the water dispenser still works.
heatman101
Sep 17, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Ice forms under tray in freezer - then water drips into refrigerator - this has been going on for at least 3 years - and we are at wits end trying to keep the drain from freezing up - what to do - the...
Whirlpool has a kit to stop the drain from plugging up. You mount a metal tab on the heater and it is long enough to slip down into the drain. When the heater comes on some heat gets transferred into the drain hole and keeps it from ice blockage. fed15be.jpg
Apr 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from top mount freezer
Hi, This is very common for this brand. UNPLUG the refrigerator. You need to remove the bottom and rear panel in the freezer. You should see an ice build up. remove the ice with a hair dryer preferred. Then with warm/hot water, remove the ice built up in the drain hole located below the evaporator coils. You will need to put on an after market drain heat transfer strip kit to keep tjis from reaccuring. I can get the part# for you if this what you find wrong. Please let me knwo if I can assist you fyrther.
Thanks
Vic
May 13, 2009 | Whirlpool ET8WWKXK Top Freezer...
Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
