Question about Nikon D200 Digital Camera with 18-70mm Lens
Nikon D200 incomplete RAW pictures
Some RAW pictures are incomplete, black bar across lower 25%-50%. Seems to be associated with use of bracket function. I use the RAW & JPEG setting for each picture. The JPEGs are fine, some of the RAWs are defective.
  • 111 Answers
If youre using exposure bracketing, especially when raw+jpeg is used, this is saving out massive amounts of data to the memory card. Have you tried using a faster (80x) memory card and/or just using raw alone? You can always make the jpeg at the computer later.
Posted on May 16, 2008
What does raw+fine pictures mean?
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
Apr 14, 2013 | Nikon DSLR D90 Digital Camera
I've recently upgraded to Windows 7 and now Bridge CS3 does not recognize raw files in my Nikon D200. D700 works fine all raw files on hard drive are okay. Have any suggestions?
Go to Adobe.com. In the support section, locate and download the Camera Raw updater. The original ACR in CS3 does not read D200 .NEF files
Apr 09, 2010 | Adobe Computers & Internet
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
How do I find out how many pictures my Nikon D200 has taken
http://www.rawworkflow.com/
Sign up and get Instant JPEG From RAW. That program has a feature that purportedly reports shutter activations.
Nov 04, 2009 | Nikon D200 Body Only Digital Camera
Nikon D200 S, CL, CH spindle has slipped....
Take it to a Nikon authorized service centre. Don't try and fix it yourself.
nikon authorized service centre Google Search
Oct 27, 2017 | Nikon D200 Body Only Digital Camera
When i use my 17-35 tamron lens on my d200 nikon on manual, the fstop jumps around on it's own. I'm not changing it. Also, as I'm taking pictures, for example if i take 5 pictures in a row in the same area...
Hi. I had the same issue when I first got my D200 years ago and just happen to come across your post. It is a simple adjustment in your Bracket/Flash mode in your menu under e. Go to (Manual Mode Bracketing) and set it to (Flash Only) and then the F-Stop wont jump around on its own Hope this helps you out.
Aug 01, 2009 | Tamron Cameras
D200 focussing brackets in viewfinder flicker and jump around
I had something similar - it could well have to do with which AF mode you've got selected. Look in the menu.
May 05, 2009 | Nikon D200 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Not functioning d200
Nikon D200 High Speed Performance
© 2006 KenRockwell.com Film vs. Digital About these reviews
enlarge
I bought mine from Ritz here. I bought another D200 from Adorama here. Also try Amazon here. Adorama usually has D200/18-70 kits in stock here. It helps me keep adding to this site when you click these links to get yours.
HIGH SPEED PERFORMANCE
General:
My D200 is fast, smooth and quiet. Unlike my D1H, my D200 makes less noise and vibration. It doesn't feel as macho, and allows me to shoot in more places more discreetly. At five frames per second it just hums along sweetly, compared to my bigger cameras which always felt like something was going to come flying off of them from all the clattering.
Buffers versus Memory Card Memory
The D200 uses two very different kinds of memory for storing images.
We're all familiar with the CF cards used to store hundreds of images. These aren't that fast and card makers rate them for write speed. The D200 uses these for recording your images.
The D200, like all professional digital cameras, has a second very high speed internal cache memory called a buffer. You never touch this. This buffer memory stores 25 frames of JPGs, 21 frames of raw or 19 frames of raw + JPG.
The buffer memory is fast enough to store all these frames at the full 5FPS rate, or faster.
The D200 is never slowed by memory speed card. The D200, like other professional cameras, has a second independent set of processors which handle writing the contents of the fast buffer memory to the slower CF card. Because this writing is done with a second set of processors you never know it's working except for the green CF light on the back. The D200 can be busy for over a minute writing to the CF card and you still have the complete ability to shoot at 5 FPS and play back.
The buffer is so deep that even under the heaviest shooting it's unlikely that you'll ever fill it. Even if you fill the buffer you can still make photos and playback, just that the maximum shooting rate will lower a bit until the buffer write and frees up at least one frame.
It takes it a 100 seconds to write 400 MB of data from 19 uncompressed RAW + Large FINE JPG files to my 40x 1GB Lexar card. As a photographer you don't care how long it takes to write. So long as the buffer isn't full the camera works as fast as ever. Even if it is full you can shoot the next shot as soon as the buffer clears enough room. You don't have to wait for everything to write to make a next shot. Even with my slow 40x lexar 1GB card, a constipated buffer and huge compressed raw + JPG Large Fine files I can make a new shot every 3.2 seconds. With uncompressed raw + JPG Fine Large I can get off a new shot with a full buffer every 3.7 seconds. If you ever get to these limits you're doing something stupid. Just shoot JPG and you'll never be able to fill up the buffer faster than you can shoot. With Large FINE Optimal Quality JPGs the buffer clears at the rate of 1 FPS. With Large Basic Optimal Quality JPGs I can run at 2 FPS even with a full buffer. Use the smaller image sizes or the Size Priority JPG setting and you can shoot as fast with the buffer full as empty!
I've had to do seriously stupid tests to fill it up.
Shot Buffer Readout
A shot buffer is fast memory inside the camera which stores the shots you've just made. Your memory card is written from this buffer. Even with the slowest card on earth you can shoot as fast as you want, since it all sits in the buffer until written. Your card is recorded in the background while you shoot. The green CF light tells you this is happening.
The size of this buffer is how many shots it can hold while allowing you to shoot at 5 FPS. If it gets full the camera slows to only as fast as your card will accept data, which is about one frame per second . These buffers are why you don't need to worry about card speed.
I've never filled up more than 9 shots in a buffer. I don't shoot that fast. With a 25 frame buffer the D200 has far more than I'll ever use.
This is the number you see while the shutter button is pressed halfway. It usually looks like [r25], which means it's empty and can hold 25 more shots. Normally you'll see a big number like [527] or [ 1.3]k, which is how many shots are left on your card. As you shoot fast sequences you can see this number drop. When it drops to [r00] your buffer is full and the camera slows down its shooting until the buffer is recorded to the card. It's fun to look at when you get your camera, but since I never fill it up I don't worry about it. You'd have to be shooting many long high speed sequences continuously with a slow card ever to use much of this.
Jan 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera with 18-70mm Lens Logo
85 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
