Question about Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
I have a dirt devil feather lite deluxe carpet shampooer model #ce6100 and it stopped letting water out of the water tank can you help me
  • Anonymous Jun 19, 2008
    The solution no longer releases when sqeeze button for release is held down. Power and suction work fine. To solve the problem, the trouble shooter page in the booklet says to make sure that the solution container is in place. Therefore, several attempts were made to secure the solution container but this did not correct the problem. the suggestion after this is to have it repaired.
  • DDenpanne Jun 19, 2008
    The cleaning solution no longer releases when blue sqeeze button is pressed. troubleshooter page says to make sure bottle is in place. container bottle was adjusted several times and this did not correct the problem
    Genius:
  • 1,665 Answers
Hi Have anice day!
see your machine layout and parts here
(Click any NUMBERED Part )
Posted on Mar 11, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 11, 2008
    See dirt water tank assy item 6 and Pump item 14.
    Check water pass not to be clogged somehow.
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
Why doesn't water comes out ?
well the hoses could be either bent or gunked up, try putting limeaway in the water tank then run it through that ought to help, but do this over a sink or something and make sure to rinse it out with plain water because limeaway can eat your carpet
Dec 06, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a dirt devil platinum force carpet shampooer,bought it at the beginning of august this year. The sprayer seems to have stopped spraying from the main tank. The shampoo tank is letting the soap out...
you bought it in August this year
as it is 2018 and only march, it is not possible to have a problem with a machine not yet made
Besides the point , it is under warranty so take it to a service agent for a warranty repair
Mar 07, 2018 | Dirt Devil M091400 Platinum Force Wet/Dry...
Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil CE6000 Featherlite Wet/Dry Vacuum Logo
882 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
