Problems hooking up a VCRplayer
I have an Emerson model TC1972DB television and I am trying to hook a VCR to it. Cable line to the in of VCR , out line from VCR to TV in. No sound or picture on any channel. Help.
  • 46 Answers
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Posted on Mar 11, 2008
How to connect old vcr-plus to emerson tv
If the TV has RCA jacks on the back, use the red, white and yellow ports on the VCR to connect to the same colors on the TV.
Dec 18, 2014 | Emerson Televison & Video
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Ok i need to know how to hook up a dvd player to the tv. I need to know now. Thank you nina
Is there a cable antenna connection on the back?
If so, hook the DVD cable out to the TV cable in.
Put the TV on channel 3 or 4.
There may also be RCA jacks so you can hook the audio and video up direct.
Jul 15, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I have an older emerson tv that I can not get to pick up channels above 36. It is pluged directly into my cable outlet. When I hook up another tv it will get around 90 channels. Is there a setting I can...
I doubt that there is a setting built or designed in your tv, older tv tuning systemslike yours were designed for what was back then available as far as channel capability(cable ready sets)what ypu can do is get a cable converter and get the channels thru the box or if you have a vcr hooked up you can always select channels thru te vcr tuner if the tuning system in the vcr is newer. thanks!
Jan 05, 2010 | Televison & Video
On my Maxent television there is not co-axial hook-up for cable connection. The cable company does not have a tuner box, what should I do to get it working?
If you have a vcr ,you can come out of the line out of the vcr.the cable box would hook to the vcr,out of the vcr to the tv. this might help
Jul 14, 2009 | Maxent MX-26X3 Television
Hooking up my VCR
OK If you are running cable you would plug cable box into VCR then VCR out to the TV input red/white/yellow/ or a coaxl cable (like the one the cable companys Good luck and Thank you for using FixYa.
Dec 17, 2008 | Emerson EWV401 S-VHS VCR
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
Lost the cable signal
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
May 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
