Question about Philips 19PS45S 19" TV
Universal remote??? new remote is rca three in one what code should I pute in?
    Genius:
  • Philips Master
  • 1,550 Answers
Porque no tratas por el siguiente metodo,prende la TV que vas a programar manualmente,en el control remoto presiona la tecla code search hasta que el led se quede encendido sueltala y despues presiona la tecla Tv. sueltala enseguida dirige el control rumbo a la Tv y presiona el boton power en intervalos hasta que la television se apague despues presiona la tecla enter para que el codigo se quede almacenado en la memoria te vas a llevar unos cuantos minutos para hacerlo pero siempre funciona.
Posted on Mar 11, 2008
  •  Francisco Mauricio G
    Francisco Mauricio G Mar 11, 2008
    Esta forma de programar viene en el manual.
It worked.. thank you!!!!!
Posted on Mar 27, 2008
What are the codes for a RCA universal remote for a Proscan 32 inch LCD TV with DVD player combo ?model number three to lb30 QD?
Two possible codes are 000 and 181. If neither works, use code search on your RCA remote to find something that does work and controls some or all functions of your Proscan unit. If a search through all codes stored in the remote fails, you may gave to try a different universal remote. All universal remotes do not store all possible codes.
Apr 26, 2017 | RCA Televison & Video
How to enter code for rca universal remote rcr311W
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 07, 2013 | RCA Universal Remote Control
What is the code for an apex digital converter box?
Hello
You haven't specified the exact model number of your RCA remote control. Three device remotes for RCA is in many model numbers. If it is RCA Systemlink-3 remote control, there is no setup code for Apex Digital Converter Box. OK.
Oct 21, 2011 | RCA 3-Device Universal Remote
Need codes for r560b
Hello
Three digit universal remote codes for RCA remote control are:
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit codes are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
You haven't given any details of the device to which the setup codes you want to synhronise with. I hereby attached three digit and four digit universal remote codes for RCA.
Oct 16, 2011 | RCA RCR460 Remote Control
Need the code for rca universal remote to a apex t.v.
Hello and welcome to FixYa. The remote code for your particular issue are listed below. I hope you found this helpful.
0156
If your remote only accepts three digits just drop the zero in front of this code.
Apr 22, 2011 | RCA Universal Remote Control
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
Programing rca rcr451 to sylvania no codes just instructions
1. press and hold code search button until it stays on.
2. press button on remote for device
3. enter three digit number and code search light should turn off and remote should be ready.
if this doesn't work here is the manual for the remote.
http://www.scribd.com/doc/2218751/RCA-Universal-Remote-Codes
May 26, 2009 | RCA Universal Remote Control
Forgot how to manualy code search on rca remote
[edit]Steps Turn on the target device, your VCR, DVD TV etc.
  1. Press and hold code search until the LED lights up.
  2. Release the code search button.
  3. Press and release the component button you wish to program. When this is done the indicator light for that component will blink and then remain steadily lit.
  4. Press and hold the code search button until the correct code is found. A new code is sent every three seconds. This can take a while.
  5. Aim the remote at the target device and press on-off on the remote until the component turns on.
  6. Press Enter to save the code.
Mar 13, 2009 | RCA Universal Remote Control
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Philips 19PS45S 19" TV Logo
481 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
