Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
My screen have some red lines
Hi i have a samsung tantus 47 " screen i i getting some red lines on my screen
    President:
  • 4,402 Answers
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
Hi i have samsung tantus 109cm rear pro tv the red is out of alinement how can i fix this
You can get the convergence board from www.tvrepairworld.com your experiencing a convergence failure with the red Circuit.
Jun 17, 2011 | Televison & Video
I need the outer screen for my Samsung HC-P4752W. Mine has a red line that seems burnt into it. Where can I get one?
It sounds like the RED CRT is cracked which will cause a red line. You can verify by looking into the lens of the Red CRT with a flasnlight if you see a line the CRT needs replacement. If no line then chances are the Convergence IC may have a problem.
Sep 19, 2010 | Samsung HC-P4752W 47" Rear Projection...
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
i had a similar problem with a 47 inch vizio lcd t.v. It would be fine for a while then all of a sudden the black areas and shadows would all become red lines in theses areas. I brought it back to the guy who i had purchased it from and he had told me that the reason for the lines was a bad video card.i got a new set and it works just fine.So i would reccomend getting a new card or sending it back to the manufacturer for them to install a new one for you. hope this helps.
Sep 18, 2008 | Samsung LTM1755 17 in. HD-Ready LCD...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Feb 17, 2008 | Hitachi 57F500 57" Rear Projection...
Samsung tantus oct. 1998 pch521r
screen control must be turned down ,called retrace lines
Sep 07, 2007 | Samsung PCH521R 52" Rear Projection...
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
