Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Power supply bad connections caused diode D4 to burn up. need the part # for this diode. Thanks can"t get no power to tv
  • 22 Answers
Here is my board that i ordered for replacement, as you can see, the top left second in --cap IS BLOWN. so i think i can either, use a cap from my other board into this and see if it works, or.....test out my current board, and use this board for parts.
any suggestions, that be great. As far as,... which diode.. maybe this can help. cheers.-- Goat
Posted on May 09, 2008
    Problem Solver:
  • 17 Answers
Where is the diode located on the board if you're looking at the side with all the components with the big capacitors on the top? That would mean that the power connector is at the bottom right.
Posted on May 08, 2008
Emerson lcd no power
There could be power supply problems even though there is no visible evidence.
Dec 01, 2013 | Emerson LC501EM3 50" 1080p 60Hz Class LCD...
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
Asus g51v dead
it is dead sorry to say theres more than you can see. use a mag glass to see all board look for water trales burnt marks all before you try to fix it ok jim
Dec 03, 2011 | ASUS Computers & Internet
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
Sep 04, 2011 | Philips 32PFL3505D 32 in LCD TV
Mitsubishi VCR HS-U57 power supply questions
The closest model I have is HS-U61 it may be the same
D901,902,903 and 904 -are part of a bridge rectifier -standard B+ diodes DSA3A1 - 264P430030
D913,D914-(connected directly to R902 through transformer winding to D914) -1SS82 standard switch diode
D917- (connected to base of Q903 and D916) 1S2076 standard switch diode.
Check if they are located as described.
Oct 27, 2009 | Televison & Video
My tv does not turn on
This problem is likely a failed power supply. This is a known issue with this model TV. It will normally occur soon after the warrenty expires. It can also be caused by a voltage surge produced by a power failure. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 08, 2009 | Akai LCT2721AD 27 in. LCD Television
TV wil not turn on at all
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Comments: Aug 31, 2009- Hey the link TODDTHETVMD is posting has a picture of the Protron PLTV - 3250 power supply. It looks exactly like that in my tv. Buy it. All you have to do is remove screws and and cables and put them back and you are all good to go. It is as easy as replacing parts and components in your computer. Thanks TODDTHETVMD.
Aug 27, 2009 | Protron PLTV3250 32 in. LCD Television
No power to my Protron PLTV 3250. What can I do
Mar 05, 2009 | Protron PLTV3250 32 in. LCD Television
TV Turns off on its own ?
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Dec 21, 2005 | Panasonic PT-53WX42 53" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
