Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
F7 error Kenmore 30465 built in oven has an F7 error and has locked up panel. How do i fix this? Already unplugged for days and still get the same error.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
Hi robpris,
My fix for the most common cause of the F7 problem can be found at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1600 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Regards,
Powerman
Posted on Mar 22, 2008
F76 error code on ge oven
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Oct 14, 2013 | GE Ovens
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 05, 2010 | Kenmore Ovens
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Error code f7 on Kenmore wall oven 911.41165791
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
May 27, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F7 error in Kenmore double oven
You can find my solution to the most common cause of the F7 problem at the following link:
I have shared my fix with over two thousand unhappy GE customers. Most report success. I hope that it works for you too. Please let me know by sending an email to:
hutchipop@yahoo.com
Regards,
Powerman
Nov 20, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Feb 23, 2008 | Ovens
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
540 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
