Car audio i just hooked up a new amp in my truck it has a remote that plugs into the amp to turn the bass u por dowm when its turned down everythings fine but when you turn the bass up the subs just pound like crazy not to the music idk if its my rcas or what it never did it with the other amp can you help?
  • 979 Answers
You do not have the proper isolation between the output of the front end and the inputs of the amp. You now have what is called a feedback problem. Get the proper iso resistors and instal them, pronto...accordianman
Posted on Mar 11, 2008
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I hooked up a system in my truck had it for a year everything working fine.i listen to music really loud anyways i have my wires hiddin under my back seat well when someone layed the seat down it cut my...
Because even though your stereo is turned down the gain for the sub is set all the way up so it will still gain a small amount of signal. it is a flaw with some of the newer aftermarket stereos. try turning the nob until the thump stops then change the bass setting on your deck to compensate for the bass loss.
Jan 28, 2011 | Car Audio & Video
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
How do you get the bass remote to work, when i plug it in i still cant control the bass
the remote wire is just to turn the amp on and off. it doesn't really turn the bass up or down.
Aug 10, 2009 | Pyramid PB1281X Car Audio Amplifier
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Voltage drop
You're drawing a ton of power from the car's electrical system. Get a stiffening capacitor and put it in on the amp's main power cable. If you're draining the car that badly, make sure to get at least a 1 farad cap, bigger if you can, and until you do, turn the gain down and don't run so much bass - you'll kill your battery in the meantime.
Jul 29, 2008 | Alpine MRD-M1000 Car Audio Amplifier
Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Oct 28, 2007 | Sony XM-2200GTX Car Audio Amplifier
27 people viewed this question
 Grubhead
Grubhead
