Question about Sewing Machines
Timing for Brother XL3200 Sewing Machine
The timing appears to be off on my Brother XL3200 sewing machine. The needle has been changed and the machine is clean and oiled. The needle hits the bobbin case when it is lowered. How do I set the timing? Thanks!
  • 1 more comment
  • Anonymous Mar 17, 2008
    needle hits bobbin case
  • Anonymous Jul 22, 2008
    I have the same problem with the timing, I go to thread the bobbin and the thread won't catch, how do I fix it myself?
  • Anonymous Dec 27, 2008
    timing is off and thread is also not being catched up by the needle..
SOURCE: Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
maureen.reinberger@gmail.com
Posted on Aug 02, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
Mimito7
  • 128 Answers
SOURCE: Needle hitting bobbin case and breaking off
It sounds like the machine is out of time.. However, it is not an easy fix at home.
Posted on Apr 19, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
My 2003 Brother sewing machine is needle keep on breaking when I try to sew
http://www.sewingandcraftcorner.com/why-does-my-sewing-machine-needle-keep-breaking
If it continues to break needles, most likely the machine has been knocked out of time. Search for sewing machine timing or take it for repair.
Mar 22, 2017 | Brother Sewing Machines
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
Timing is off
Unless someone has worked on the machine it is rare for the timing to be off. What symptoms are you seeing that makes the timing appear off? Other, more common, things that can appear to be timing related include: 1) incorrect needle or needle is set wrong 2) wrong bobbin or bobbin isn't seated correctly 3) upper thread is through the needle incorrectly (left to right, right to left, or front to back) only one is correct
Jan 16, 2013 | Brother CS6000i Computerized Sewing...
How can I adjust the timing on a brother ls 1217 sewing machine
Unfortunately, it's not recommended for users to repair their own brother machines. It sounds like the timing is out anyway... to take it in and have it "Cleaned, Lubed, timed and the Tension repaired"
Or you could use it for target practice and just go buy another machine.
Dec 12, 2012 | Brother LS-1217 Mechanical Sewing Machine
How to retime a brother 900d sewing machine
Breaking threads isn't necessarily a timing problem. Check for burrs.
Nov 11, 2012 | Brother Innov-Is 900 Sewing Machine
I have brother xl3200, can i free motion sew on that?
can you drop the feed dogs on your machine ? if you can then you can
Jun 30, 2010 | Brother XL-5130 Mechanical Sewing Machine
I keep getting loops (from the upper thread) on the bottom of the fabric i'm sewing. I thread the needle with the foot up and changing the tension doesn't make any difference. I'm using the correct, unbent...
The machine will need to go into the shop as it appears the timing needs to be adjusted.
If you are mechanically inclined, you can find a tutorial and graphic at sewusa.com for adjusting the timing.
Mar 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
380 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
