Question about Dual XDM6830 CD Player
Detachable Face Can not attach face unit to stereo. The left round cylinder that hold the left side of the face will not attach to the unit. Do you know of any way I can repair this. Or do you need more information. Thanks Greg
  • Grego50 Mar 11, 2008
    Please help.
SOURCE: face plate
the face plate is not removable it only folds down
Posted on Apr 15, 2008
  • 2336 Answers
SOURCE: face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
Posted on May 04, 2008
snafu86
  • 193 Answers
SOURCE: I just bought a Dual XDM6820 and installed it
If the cd's come in and out fine then it has something to do with key wire (red) . I try and always use and a adaptor harness when installing aftermarket decks. Make sure your wires are well inulated and not pinched when deck is "in its place".
Posted on Jul 21, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
  • 3 Answers
SOURCE: static noise from car stereo
I had a static/hiss sound coming from one speaker on my Sony head unit. The stereo was brand new and had just installed it. The stereo that it replaced had no static. Turns out it was the input setting on the separate amplifier being too high. The stereo has 4 volt pre-amp outputs.
Posted on Jan 17, 2011
KDC-M435U is the type of stereo I have,I went and started my car the other day and the stereo was flashing protect. I took the face off and put back on, same thing. is there a reset button anywhere?
Should be a very small reset on unit behind the detachable faceplate. You will need a paperclip or something to push and hold the reset bUpton for bout 5 sec.
Jan 14, 2017 | Car Audio & Video
Replaced Car battery, now stereo not working properly
Have you tried resetting the microprocessor?
Remove the detachable face. There is a small pinhole on the front of the radio about two inches from the left side near the bottom. Press this in lightly with a fine point pin or paper clip. Hold about 3 seconds, then release.
Replace the face and try it. Let me know.
Dec 16, 2013 | Sony Xplod CD Player w/MP3 Playback...
FACE OFF KEEP S COMMING OFF PIONEER DEH-14UB
hi teresa, you have a problem with the face latch on the unit, or the holding groove behind the detachable face. have the mounting of your unit checked out by an installer as well. check for broken plastic holder section of the units front chassis. if all checks out well then best you have your unit seen to by a technician. cheers.
Jun 22, 2012 | Car Audio & Video
A problem started with my Panasonic CQ-C9700N car stereo recently which involved the complete facia powering off. However the stereo would still work in the mode it was left in. Every now and then it would...
if im not mistaken, that model has a detachable face plate. What happens a lot of the time is the connections between the face plate and the unit get corroded. Take the face plate off and (with fine grit sand paper) lightly scuff the electrical connection clean on both the unit and the face plate. It also doesn't hurt to use a little dielectric grease before you reattach it... this method has work several times in the past for me... Hope this helped!
Apr 29, 2010 | Car Audio & Video
How do you set the time for a jvc kd-g3k detachable face car cd player?
Press and hold the SEL button until DEMO appears. Use the up/down buttons on the right hand side of fascia to scroll down to clock adjust, and use the circular dial to adjust the time
Jan 14, 2010 | JVC AM FM CD DET FACE CAR STEREO
The detachable face plate opens up when i turn off the ignition
This is a option you can disable in the menu, it is meant to make it easier to detach the faceplate when you leave the car
Apr 12, 2009 | Pioneer Car Audio & Video
I have a pionner deh-6900ib. the detachable face of the stereo has water in it so when its attached to the unit there is no dipslay and the buttons are not working. how can i get this fixed??
you can go to a stereo store or wal-mart or anything like that and tell them that you need a new face for you stereo tell them it's a pioneer deh-6900ib that way they can make sure to get you the right one..
Dec 04, 2008 | Car Audio & Video
PIONEER DEH-P7700MP/P770MP CD/MP3 Faceplate
do you want the detachable face or the case to hold the detachable face?
Here is the detachable face at the Pioneer site:
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Here is the case for the detachable face:
http://parts.pioneerelectronics.com/part.asp?productNum=CXB3520
You might find the face, or even the whole radio with face cheaper on ebay.
Jun 20, 2008 | Car Audio & Video
Clock settings
Phaedrus De Wolf--
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
Nov 26, 2007 | Pioneer DEH-P2900MP CD Receiver...
How to detach face of lanzar stereo?
Here is a link to the owner's manual: http://www.lanzar.com/manuals/VBD1700MP.pdf (Note that the "DCP release button" is the upper-leftmost button on the unit.) On page E-5, it says: 2.DETACHABLE CONTROL PANEL (D.C.P.) Removing The Detachable Control Panel (D.C.P.). 1. Turn the power off 2. Press the D.C.P. release button 3. Remove the D.C.P. Attaching the DCP CAUTION 1. Attach the panel at the right side first, with point B on the main unit touching point A on the D.C.P. (As shown on the digram). 2. Then press the left side of D.C.P. onto the main unit until a ?click? sound is heard. DO NOT insert the D.C.P from the left side. Doing so may damage it. The D.C.P can easily be damaged by shocks. After removing it, place it in a protective case and be careful not to drop it or subject it to strong shocks. When the release button is pressed and the D.C.P is unlocked, the car's vibrations may cause it to fall. To prevent damage to the D.C.P, always store it in a protective case after detaching it. The rear connector that connects the main unit and the D.C.P is an extremely important part. Be careful not to damage it by pressing on it with fingernails, pens, screwdrivers, etc. Note: If the D.C.P is dirty, wipe off the dirt with soft, dry cloth only. And use a cotton swab soaked in isopropyl alcohol to clean the socket on the Socket back of the D.C.P.
Feb 16, 2007 | Lanzar VBD2200MP3 Motorized Slide Down...
Dual XDM6830 CD Player Logo
59 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
