Magnavox TV problems
When I switch on my Magnavox TV, it just starts displaying all the features of it. I can't change the channels or switch it off with or without remote. Only way to switch it off is to unplug it.
  • jabardast Mar 14, 2008
    Thank you Slinteriors.
    I don't have the manual for this TV.
    Could any one guide me on how to bring it out of demo mode?
Tell him how to get an user manual
Posted on May 08, 2008
  • 8,617 Answers
Your tv is in the demo mode. You will need the user manual to get it out of demo.
Posted on Mar 11, 2008
I have a 50" philips magnavox tv that changes channels on it own and turns itself on frequently. What is causing this issue?
Do you live with someone who likes practical jokes; even silly ones?
There are a number of companies that make remotes that can mess with someones TV or other remote devices.
I have a watch, as a gag, that will self program its remote to operate any TV capable of this feature. With this watch, I can change channels, power status and even reset the TV to factory default state.
Next time this happens, look behind you.
Jan 15, 2013 | Televison & Video
Ur5u-8780l not operating channels on Magnavox TV. Tried all codes and switched channel control to TV, still nothing.
If you are using a universal do not expect it to even if it programs to have all the functions you need or want or had with the original remote.
Universal remotes are far from UNIVERSAL.
The best argument for an original remote is even if it programs it will just not have all the features needed or wanted that the original had.
Hope this clears things up a little.
Apr 03, 2012 | Televison & Video
Word Component1 shows up when changing local channels
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
Apr 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Channel display
Here's a link to your owners manual if you need it. I'm sorry but I didn't see anything other than pressing the display button to see what channel your on.
http://www.m4c.magnavox.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Oct 16, 2008 | Philips Magnavox 27MS343S 27" TV
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
premtech@willapabay.org
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
Magnavox tv
Hold both vol up & chan up on front of set for at least four seconds.THen demo mode will release.
Oct 03, 2007 | Philips Magnavox 27MS343S 27" TV
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Black Box
i had the same problem with my rca truflat.. i read from a posting of a similar problem with a different tv brand to switch your closed caption options 'off' or set it to a 'cc' option instead of the 't' options.. (this was done through the on-screen menu..) i gave it a try and it worked for my tv.. hope it works for you..
Aug 16, 2006 | RCA 20F610TD TruFlat TV/DVD
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
