Question about Mitsubishi Televison & Video
Blue Pixels I have just started seeing blue spots showing up on the screen of my Mitsubishi WS-65513 projection.
When all else fails, hit the reset button. Pushing the reset button on the set cleared the problem.
Posted on Mar 11, 2008
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Cant reset blue convergence on rear projection WS-73905 73 in
Please rate!
First the yellow tinge is due to the blue STK convergence IC possibly being burned. Usually on the right lower side,sccessed from the back, is a module with 3 black stk's on it. If you see the stk's then replace all 3. Not one as the others will blowreally soon. Also check to see if green coils are burned if, so replace them. Get parts from matelectronics.com. Good source and inexpensive, about 40 bucks for the parts...Give a good visual and then proceed. be careful! high volts still in there, but don't worry...
Mar 10, 2009 | Mitsubishi WS-65513 65" Rear Projection...
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
How do you changea mitsubishi dlp tv lamp, bulb only?
A ws-65513 is not a dlp and does not have a lamp. Is WS-65513 your model number? If not what is it?
Sep 17, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws65613 no picture or sound, blue screen only
Good Day;
Blue screen that has gotten worse over the past few days, I would suspect fluid on your signal board.
The three CRT's in the TV has coolant that tries to keep them cool but they have a problem with the 'glycol' leaking out of it's chamber.
Take speaker grill off, remove panel and look on the right side of opening. Look for fluid on the board, shinny substance, it's hard to see so look closely. That is the most common problem.
2&3 are the CRT's or the CRT's drive circuit.
Good Luck, Day,let me know, Big Irish.
Jun 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513 won't turn on
Probably blue a fuse in back is what you saw. But something caused this to happen. You can replace the fuse but something else is probably damaged. For more info ctechnicians.com
Jan 06, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
