Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Hard drive encolsure problem
I cant get my hard drive into enclosure
  • 133 Answers
U just need to look at it carefully coz it has a way it goes in.
Posted on Mar 11, 2008
My samsung G2 cant read, it ask to be formatted but it cant be completed n propreties shows 0 used space, 0 free space
Most likely the hd is bad. If you want to know for sure purchase a usb enclosure, break open your drive case and put the hd in the enclosure. That will tell you if it's the hd or the circuitry of your case.
Oct 29, 2012 | Samsung G2 Portable External HX-MU064DC/...
I HAVE A NEXTECH 3.5 EXTERNAL hd ENCOLSURE, BUT ITS NOT RECOGNISED AFTER i REPLACE THE hd WITH A wd 500gb hd, why, I SET IT TO MASTER AND ALL OTHER SETTINGS BUT STILL W/N COME UP
go in to your bios and change the setting for the hard drive. If this does not work? go to WD web site
and download the hard drive software for your hard drive. next make sure your nextech and WD is
compatable?.....hope this helps!
Jun 02, 2011 | Computers & Internet
I have a Western Digital external hard drive. It just sits there and suddenly I cannot find it in Windows Explorer. It does show up under Device Manager, and I have uninstalled/reinstalled the drivers,...
Welcome to Fixya
Try to plug it in to a different computer. If you are getting the same thing using a different computer then its gonna be the enclosure or the HD is having the problem. One way to check is to use an extra HD and put it inside the enclosure. If the enclosure was able to detect the new HD then its gonna be you HD that is having the problem. If enclosure still cant detect the HD then the problem is the enclosure.
Please let me know if you need further assistance.
Thank you for using Fixya!
Apr 19, 2011 | Western Digital 320GB MyBook External USB...
When i plug it in to usb drive blue light flashes only once but it is not shown on my list of devices on my pc and i cant veiw photos on it
The power supply on the drive has failed. What you can do is take it out of the enclosure and put it in a new hard drive enclosure. I had the same exact problem one time. I took the drive out of the enclosure and intalled it in my computer tower.
Mar 17, 2011 | Seagate (ST625211U-RK) (st625211urk) 2.5...
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
Cant access files on my harddrive
It sounds like either the enclosure or the drive inside has failed.
If the enclosure has failed and you don't have any crucial files on it that you don't already have elsewhere, contact Maxtor(Seagate) for a warranty replacement.
If the enclosure has failed and you DO have important files on it, try having your local PC shop move the hard drive into a new enclosure, if that works you're done, buy the new enclosure.
If the new enclosure fails, your drive is damaged and you will need a pro to help get back your files. If this is the case, reply back with you location(Country, State and City) and I will pass along recommendations for your neck of the woods.
Hope this helps FixYa,
Chris
Oct 24, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Driver software for3.5inch IDE , Black by Eforcity (POTHIDEX3501) IDE / EIDE HDD Encolsure
No drivers should be required for standard enclosures.
You should check that you are only using the cable that came with it to connect to the computer (not one that fits the same)
It MUST be plugged into a usb 2.0 port NOT a usb1.x
You should not plug it into a usb hub
It must have it's own power supply for any 3.5" enclosure
Also make sure your motherboard drivers are up to date and that there are no exclamation marks by any hardware in the hardware tab from system.
Aug 20, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Where
There are a variety of things that can malfunction on your external hard drive:
1) The USB cable - Have you tried switching the USB cable?
2) The external hard drive casing
3)  The hard drive itself
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
I/O Magic Technical Support
May 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Western Digital 120 GB Hard Drive
Well usually external hard drives are just a regular hard drive in an encolsure! You can try to mount the hard drive to a regular pc using the ide/sata connector(Im not real sure which interface your drive will use). From there you can tell wether its the actual drive that is giving trouble or just the USB enclosure! Most of the times with those name brand external drives its a lil complicated to figure out how to take it apart to take out the hard drive. What you can also do is try(if you get it open) to see if you can unplug the hard drive from the enclosure then power on the enclosure and see if the lights come up green(or whatever color it uses to indicate ready)! if it does then power off the enclosure then re-connect the drive to the enclosure and power on again! Maybe that works! Removing the drive might void your warranty, proceed at your own risk! Good Luck regards, babb
Apr 30, 2007 | Western Digital (WDXU1200BBRNN) 120 GB...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
175 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
