Question about SanDisk Sansa e260 MP3 Player
My e250 won't display
I can turn it on and the control buttons light up, but the display does not. i even changed the battery, but no difference.
  • 8,596 Answers
Try reset method. if that fails:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 23, 2008
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
Westek TE06WHB Timer has been plugged in to charge for over 5 hours now and still now LCD display. It won't let me set the clock or program
Some of these timers use actual battery instead of rechargeable battery. Check back of timer for a battery door.
Press the reset button and see if this resolves the issue.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Check outlet polarity using circuit analyzer.
Plug timer into another outlet.
Turn on light switch controlling outlet.
See if a light works on same outlet.
Check circuit breaker.
This timer has 1 year warranty against defects in workmanship.
I suggest always buying timers at local store for ease of possible return.
Lowes and Target sell same/similar timer under different brand name. Buy new timer and return defect in new package.
Sep 05, 2012 | RTO Westek Weekly Digital Timer, White
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Proform GR 80 won't turn on even after new batteries, how do I fix?
On mine, I found that the battery contact springs on the inside of the control head (not the ones on the battery lid) were flattened out and were no longer making good contact with the batteries. I used a small hook to stretch them out a little so that they could make contact. As soon as I put the batteries back in I saw the display light up and now the bike works normally again.
May 17, 2012 | Exercise & Fitness
E250 won't turn on
Try resetting the device by pressing and holding down the Menu button for 15 seconds.
If that does not resolve the issue, then you may need to replace the battery in the device.
Feb 09, 2012 | SanDisk Sansa e250 MP3 Player
Ford e250 brake lights stay on
If the lights only stay on when key is in ignition, your central brake lights (or one of the lights) are out. The other lights stay on as a warning that the centrals(or other brake light/s) are needing replaced.
Feb 07, 2012 | 2003 Ford E250
How do I reset the computer after changing the battery in my 2004 mini cooper S? The car started three times. Now it won't start even though all of the other electrics work
Turn off ignition. Press and hold the trip reset button, then turn the ignition on (don't start the engine), within 5 sec the SIA status will be displayed. Release the reset button. Press and hold the trip reset button for 5 sec, "rst" will be displayed. Release and re-press trip reset button.
The new status should be displayed.
Oct 02, 2011 | 2004 Mini Cooper
3 days old and when I push any of the buttons that are supposed to cause belt to start moving or to change incline there in no response, though the electronic display starts counting the seconds as if it...
The single most cause of no motor output is failure of the DC motor control Look for any test lights on the power boards beneath the motor shroud use caution when removing the motor hood because you may still have electricity in the motor area even if the treadmill is unplugged.
One of the lights should be labeled PWM when hitting the start button that will start flickering , because the upper console is sending a signal to the lower board telling it to start the motor. if that process happens then you need to check the motor
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery. If does move then the controller board needs to be replace.
May 24, 2010 | Nordic Track NordicTrack Elite 9500 PRO...
SanDisk Sansa e250 MP3 Player display gone blank
I believe this is answered already. Turn the hold button on. Red light will be on. Hold the rewind button while you insert it into the computer. Please search online this has been answered. I am recalling from what I read a few minutes ago.
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
