How change battery in h605 bluetooth headset - Audio Players & Recorders
  • 979 Answers
Oh so gently find the tabs that hold the thing together and pry apart....accordianman
Posted on Mar 11, 2008
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
Change battery
You'll have to contact apple support, their notorious for making it impossible for users to make their own repairs. Discussion threads on Apple iPhone Bluetooth Headset Battery Change Charge indicate that other users have the same issue on the only real recourse is to take it to an Apple authorized repair center or Apple Store for service. It's very likely that it will cost more to repair than it would to buy a newer BT device.
Jun 11, 2013 | Apple MA817LL/A Bluetooth Headset
How to open bluetooth headset motorola H730 to change the battery
Jorge
The battery is not replaceable by consumerrs. Mark
Motorola Support
Sep 24, 2012 | Motorola Mobility H730 Bluetooth Headset
Have not use the bluetooth headset(Model: LG HBM-760) for more than a year. Unable to charge the headset now, suspect headet internal battery dead, please advise how to replace the internal battery? Thanks
since you have not used it for more than a year, it only mean that the battery is totally drained, you just have to be a bit patient charging it. just wait til the light gets on. if after an hour or so and it's still the same, then it's time to change the battery or the headset itself.
Aug 06, 2010 | LG HBM-760 Bluetooth Headset
How to change the battery of Sony-Ericson HBH-610
figure out how to open it then take the battery out then put in the new one duh
May 02, 2010 | Sony Ericsson HBH-610a (Auto Pairing)...
Bluetooth h700 setup
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 20, 2009 | Motorola Mobility Bluetooth Car Charger...
I Also Got Bluetooth headset from a friend.
Changing the headset is not going to change the battery drain on the phone.
Aug 12, 2007 | Motorola Mobility H350 Wireless Headset
Bluetooth problem
Go to control panel and look for My Bluetooth Devices and double click it and click search for new devices, only then will you be able to set it up.
Jan 22, 2007 | Nokia Mini USB Bluetooth Dongle w/...
 Grubhead
Grubhead
