Question about Whirlpool GEW9200L Electric Dryer
Dryer problem I have a Whirlpool dryer# gew9200lw1 and the control panel lights will not come on. The dryer automatically comes on when I shut the door but no heat. If I shut the door and press the control on button, the control panel lights come on but still has no heat. Thanks for any help you can give me.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Whirlpool Dryers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Model GEW9200LW1 "Control Locked" light is on and dryer won't start. How do I unlock the control?
you have to push and hold the button that has the lock symbol next to it. i think on this it is on the far right hand side on the control panel.
Mar 14, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool gew9200lw1, dryer does not heat everything checks out ok, replaced electronic control worked for a day then stopped working please help. The sensor and wire harness reads a short and no...
if limit switch has no continuity than it is bad,the heater will not come on.before you change the switch you nead to make sure that you do not have a blockage in your vent hose,make sure vent hose is clear from dryer to outside vent.a blockage in the vent hose will cause the high limit switch to go bad.
Jul 03, 2009 | Whirlpool LER5636P Electric Dryer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
130 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
