Color spots on 61" LCD Panasonic rear projection tv
Hi - I've researched the color spots appearing on our Panasonic 61" LCD tv, right now there a three in consistent areas - 2 blue and 1 green, approx 4 - 5 inches in diameter. Based on the solutions offered to other persons, it sounds like an eprom upgrade may do the trikc. My question is how do I contact Panasonic or a Panasonic technician to fix the problem? Thanks very much for your help!
  • 4 more comments
  • abinney Apr 21, 2008
    colored spots all over the 44 LCD rear projection TV
  • Anonymous Jun 13, 2008
    I hav ethe same problem a 52 lcd the question is how can you fix it
  • atckid Jan 04, 2009
    I have the same problem on a 52" LCD Projection. Two blue and one red spot.
  • txmedic03 Mar 07, 2009
    My 61" LCD Projection has the color spots of a smaller dimension and some colors displayed on screen will have a waverying discoloration.
  • Anonymous Mar 30, 2009
    52" LCD Panasonic rear projection tv. Currently one Blue and one Red spot (not looking forward to there being more). Does anyone know how to fix this problem?
  • MrWizard1946 Apr 07, 2009
    several color spots on screen either TV or DVD mode
    Fade in and out depending on the Background or picture color
Rowdie1 is correct. You just need to call panasonic (number on website). Have your model and serial number handy. You have to go through several holds but you will eventually get scheduled for a service call with local authorized dealer. Tech takes the back cover off and plugs in a eprom reader/writer. Turns on TV. I sit and watch the dot go away after about 4 minutes. He lets it run for about two more minutes then all done. On service ticket is says "installed corrections". And best of all, no charge!
Posted on Jul 22, 2010
Had the same problem on my 52" LCD rear-projection Panasonic,
contacted Panasonic support (number is on their website) and after
several transferred calls, they set up a service call with an area
service rep, who callled the house that evening to confirm appointment.
He came to the house, removed the set back cover, and installed an
EEPROM upgrade, problem is fixed and was told problem will not re-occur.
No cost due to Panasonic extending the warranty to fix known issue with
sets. (Mine was over 3 years old).
Posted on Apr 17, 2009
2000 PANASONIC TV WITH RIGHT SIDE OF PICTURE THE GREEN AND RED COLORS ARE ABOUT A 1/4" OFF FROM EACH OTHER
trysetting the convergence on the tv itself,if that doesnt work you have a bad convergence amp maybe just 1 of them,you have 2 1 for greenand red 1 for green and blue,hope that helps.
Jan 17, 2013 | Panasonic Televison & Video
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
I have 2 panasonic tv's now have both green and blue spots present
Call Panasonic and they will schedule this problem to be corrected in home and pay for it.
Sep 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Televison & Video Logo
2,927 people viewed this question
Top Televison & Video Experts
