Question about Philips 42PFL5332D 42 in. LCD Television
Phillips hdtv I had work done yesterday on my cable. Now my tv will not switch between 1080 and 480 automatically. I have to view 480 on another input. I did not have to do this before. Could there be something hooked up incorrectly or should the tv controll this. I too have the same problem. I am using an HDMI cable and the tv only registers 480p. More specifically, I have a Panasonic 1080 DVD player connected via HDMI cable. I know the tv only displays 720p, and 480 really sucks!
  • 92 Answers
If the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Posted on Mar 12, 2008
Hi i have a sansui sty1842 hd led but my ps2 is not working on it. i have plugged in the red, white and yellow cables and nothing
First of all make sure the cables are connected to the correct inputs, which you have probably already done. After that, I had the same problem with my sons tv when we got it. His is a phillips 42". I had to go to the phillips website and download a patch, copy it to a flash/thumb drive and plug that into the usb port on the tv and install the patch from the tv's menu. After that the Playstation worked fine.
Oct 05, 2012 | Sansui 42" Widescreen 120hz 1080p Led Hdtv
I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Dec 08, 2009 | Philips Televison & Video
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
No sound or picture
on the Vid/Audio cable, there is a switch for TV and HDTV, TV is for yel,whi,red ONLY. HDTV is Gre,Red,Blu. You can't use the HDTV cables on a regular TV. it can be done the otherway around. but when using the Gre,Red,Blu cables, make sure the switch is on HDTV. Same thing with yel,whi,red, except the switch should be on TV.
Jun 02, 2008 | Microsoft Xbox 360 Console
Phillips hdtv
to switch that you need rca 3 color red, blue, green to view
more that 480i , or HDMI conection
Jan 20, 2008 | Philips 55PW9363 55" Rear Projection...
Web viewing:
I was wondering are you working on tv or computer?To the best of my know how never heard of hard drive in TV! Please inlighten me.really confused on this one.
Dec 04, 2007 | Philips 60PP9202 60" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 42PFL5332D 42 in. LCD Television Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
