Question about Microwave Ovens
Microwave door handle replacement
I looked under the door, but there are no screws to take out
  • 6 more comments
  • trampus Mar 11, 2008
    Can I get an answer for this statement?
  • DocAdam Apr 02, 2008
    I have removed (easily) the plastic trim inside the door, but there is a metal frame that covers 1 of the 2 screws that hold the hadle on to the door. I need to replace the handle, but I cant access the screws to get the handle off the door.
  • Anonymous May 30, 2008
    Have Magic Chef over range microwave MCO153UWF. Handle broken,can get replacement $50.00. But how do you get into the door to take out old parts, without messing the integrity of the door?
  • Good Wife Jun 02, 2008
    My microwave handle has peeled for the 3rd time. It was covered under warranty the first 2 times and now they have no record of ever replacing it. I have purchased the handle so I could replace it myself... but I am having trouble. I can remove the plastic trim around the first 2 screws, but now I cant get to the second 2 behind the metal frame inside the door. If you have any suggestions, please let me know.
    Thanks,
  • BLeMay Jun 04, 2008
    HOW DO I REPLACE THE HANDLE? HOW TO BREAKDOWN THE DOOR?
  • Anonymous Jun 13, 2008
    microwave door hanlde broke. plastic pins broke releasing the door handle.
  • kskomer Sep 10, 2008
    Help, I ordered a replacement handle for our microwave and my husband has ripped the old handle off and in the process broke some plastic pins. Now we can't figure out how to access the screws inside the door to assemble the new handle.
  • patlconner Jan 07, 2009
    i have the new handle can't find where to replace it.
    Genius:
  • 3,587 Answers
Let me check that model number again..
Posted on Mar 11, 2008
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
Door handle broke on my Maytag MMV4205AAQ microwave. It broke once before while under the first year warranty so I know that repair requires replacing the whole door.If I purchase the part (PS909599), how...
Hi ,
There is a inner door trim on the inside of the microwave door that can come off to expose the screws for the handle. This trim is held in place by clips built into the trim, ( some older models may also have screws - look for them and remove before going any further ) the tabs on this trim can break easily but with a putty knife and some patience, the trim can be removed to get at the handle screws. See picture help. This trim can be pushed so the clips will "pop" back into place after the handle repair.
Sep 30, 2008 | Microwave Ovens
Inneed to replace the door handle. I have the
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back and let me know. If the model number you listed this quesiton under is correct, you can refer to pcappliancerepair.com for some excellent exploded view diagrams of your microwave that confirms how the door is assembled. The part numbers for a new handle (if you haven't purchased one yet) are: 8169737 - (White) 8169738 - (Black) 8169739 - (Biscuit) 8184264 - (Stainless) Make sure you use the correct part number when ordering to ensure you get the correct color to match your appliance. I hope this helps you.
Feb 17, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
First, never remove the door. You will disturb the alignment which holds in the microwaves. Generally, the door can be disassembled by removing the screws on the cavity side of the door. Once inside, then you should be able to replace the handle. Often the screws are of the torx variety...also call star.
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Replacing door handle
The choke cover (or door gasket on your brand) will come out similar to the diagram shown below.
Then the hidden screws should be visible.
Also, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 20, 2007 | Maytag MMV5156AAS Microwave Oven
Microwave Ovens Logo
344 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
