Question about Pioneer VSX-D912 Receiver
OVERLOAD My receiver has overloaded and powered off. I tried to reset it by holding down the On/standby button and the TONE button for 3 seconds. When it asked to Reset? I hit TONE and after it said OK? I pressed TONE again. It still almost immediately powered off. What do I try next?? Thanks
One or more output power trasistor short
Posted on Nov 19, 2016
  • 979 Answers
Turn the unit all the way down. Now, before you try to power up again, make Absolutely Certain that there are no shorts or damaged wiring going to the speakers. Still no go? Then try to power up with no wiring attached. Good? Now just the wiring, no speakers. Make Sure that there are no wires touching! Then try speakers. If there is a problem, you'll find it .....accordianman
Posted on Mar 11, 2008
My pioneer sx-316 multi channel receiver is off on protected mode what do I do to restart
I read the instructions perhaps slightly differently perhaps. I take the instructions to mean first hold down tone and then hold standby/on key for three seconds. Have you tried doing it as two steps?
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see 'RESET?' appear in the display, press the ENTER button. OK? shows in the display.
4 Press SETUP to confirm.
Feb 03, 2015 | Pioneer New Original SX316S Remote Control
Overload message on my janome 8000
I know you said you have performed the reset sequence, but try these steps and see if the unit goes through the diagnostics correctly.
  • Turn off your Janome MC8000. Wait for a few seconds.
  • Press and hold the "Start," "Reverse" and "Auto lock" buttons at the same time.
  • Release the three buttons once your Janome MC8000 turns on.
  • Locate the plus (+) sign on the machine screen. Press the plus sign when prompted. Wait till you receive a message that says "Test Complete."
5
  • Turn off the Janome MC8000. Wait for a few seconds.
6
  • Turn on the Janome MC8000 once again. This will prompt the embroidery machine to conduct a diagnosis. Wait till it finishes the diagnosis and troubleshoots the errors you were encountering before.
Nov 10, 2013 | Janome Memory Craft 5700
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
A few seconds after pressing the power/standby button on my SR-96 an acute click can be heard. Currently, from what seems to me to be the same area as the aforementioned click, a similar click can be heard...
The clicking is probably from a relay that is protecting from an overload either misinterpreted or real. Overload circuits can also fail or you have a component that is intermittently shorting causing a momentary overload.
Mar 27, 2011 | Marantz SR-9600 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
My pioneer receiver vxs-918v standby/on button is blinking and will not work. We were watching a movie last night and it just went off. It will not do anything except blink. The manual just says call a...
With the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Also, check the back panel for any loose wires. If a speaker wire is touching the metal it can overload the unit.
Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Dec 28, 2009 | Pioneer VSX-918V Receiver
Amp err
Same problem here VSX-916 AMP ERR
Jan 28, 2009 | Pioneer VSX-D912 Receiver
How do i reset my Pioneer SX 316 Surround Sound System. i lost the owners manual.
1. Switch the reciever into standby.
2. While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3. When you see RESET? appear in the display, press the ENTER button. OK shows in the display.
4. Press SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Aug 08, 2008 | Pioneer Audio Players & Recorders
Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Oct 17, 2007 | Pioneer VSX-D411 Receiver
Overload????
Audio amps need replacing.
Sep 08, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-D912 Receiver Logo
537 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
