Question about Relisys RLT1720 17" LCD Monitor
PROBLEM WITH MY SCREEN LT916S
MY SCREEN MAG 19" (LT916S) GETS READY THE FIRST SECONDS I PUT ON MY COMPUTER AND GOT OFF FEW SECONDS AFTER.
ADAM.
  • stevedap Aug 25, 2008
    A friend gave me her 3 year old 17" LCD monitor (unbranded made in China) that was working perfectly before I brought it home. When I connected it to my computer and turned it on, the screen flickered white with random horizontal black bars for about 6-7 seconds then went black and the led light went from green to amber. It does this every time I turn it on. Any ideas on what this problem could be. Burned out capacitor maybe? Is it worth trying to diagnose and fix? Any suggestions would be very appreciated.
    Novelist:
  • 138 Answers
Hi Did you check your monitor with another computer? If it has the same problem, there will be something wrong with your LCD monitors. Firstly, Power on both CPUPROBLEM WITH MY SCREEN LT916S - 1.gif and monitor. After it got off by itself, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
If you have any question, feel free to let me know. I will help you as much as I can. Good luck. Thank you
Posted on Mar 13, 2008
Have a Mag 19" monitor, model LT916s. Screen is
Sounds like a silly question but have you checked the fuse? If it isn't that then it sounds like a problem with the power board. Check it for burn marks and bulging electrolytic capacitors (they're the little round tube like things that stick up), also check any fuses on the board. If it's the caps or a fuse then just replace them, if something else is burnt out then you'd have to replace the board but you might not be able to find a replacement since it's old.
Feb 17, 2011 | Mag Innovision 19" LCD Flat-Panel Monitor...
Screen stays balck
if the power indicator is on will mean either a fault with the back lights or the inverter circuit that controls them will need to be checked by tech
Jan 05, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
I have a mag lt 2219 and everytine I turn it on it goes black
moz-screenshot.jpgHello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blown a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, iff so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor goes blank then displays "mode not supported"
INstall the correct Video graphic card driver. The driver CD must have been shipped with the Monitor. Just put that CD in, and follow the on screen instructions.
Mar 27, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAGinnovation LT916s
Hi...there,
It's seems you need to replaced a new backlight inverter. Check this site out...@ www.3rd-rocks.com
maybe have what you needed... Have a nice day!
Jul 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
How do you open a Mag Innovision LCD Monitor LT916s ?
There may be some interior support hooks that keep it together.  look for metal clips between the crease of the front and rear pieces.  Definitely use caution with opening as you do not want to force pressure against the screen.
Dec 21, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Relisys RLT1720 17" LCD Monitor Logo
27 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Marcin
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
