Ps36109 tv makes faint beeb but wont turn on - Televison & Video
  • 8,617 Answers
After the beeping does the Led blink a certain numbers of times before pausing a second? I will need to know that information as well as the chassis number of your proscan. The chassis number should be on a tag on the rear next to the model number.
Posted on Mar 11, 2008
  • 818 Answers
1 see and test the flyback with extreme control, because is a dangerous component of tv. This can be the problem.
Sergio
  • Sergio Scalfaro
    Sergio Scalfaro Mar 11, 2008
    if you not make it, go to tv repairman, your life is more important of 1 tv.
    Sergio
  • 19,396 Answers
The only way to get a handle on the real problem is to have proper
troubleshooting performed on that chassis. This will include starting with
hooking up the Chipper Check computer interface and software to the set to
check the error codes, performed standard tv troubleshooting of the power
supply and deflection circuits, and go from there.
It will cost you far less to have a qualified technician with the proper
equipment do a repair on the set than it will to throw parts after parts
guesses at the tv set.
    Master:
  • 555 Answers
This one's a job for the TV repairman, unfortunately
No color,only black and white
Check the color system adjustment. Make the system selection to 'Auto"
Apr 11, 2012 | Proscan PS36109 36" TV
Remote control doesn't work
What do you mean, it should turn on with the power button, try changin the batterys if not the IR unit is dead you can pick up a univeral remote at any radioshack..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Proscan PS36109 36" TV
Sounds like it wants to turn on but shuts off
Sorry but the clicks is the protect circuit saying you got a big problem. Usually, there is a short condition inside. If you have a multimeter you can start around the HV circuit checking for shorted caps or diodes or Transistors, otherwise it's a shop repair...Safety first....residual voltage remains even with power off, so be careful..
Mar 09, 2009 | Proscan PS36109 36" TV
My tv wont turn on.It just beebs it even beebs for a second or two after its unpluged..?
sounds like your display has gone check to see if the speakers r makeing any noise and i would sugest takeing it to your local tv repair shop.
Mar 08, 2009 | RCA F36676ET 36" TV
52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Oct 06, 2008 | RCA D52W19 52" Rear Projection Television
Ps36109 makes faint beep in back wont turn on
Good day.
Faint beep signifies a problem in your power supply section. Have it check by a repairman since this is an internal issue.
chris
Mar 11, 2008 | Proscan PS36109 36" TV
TV won't stop beebing
Now I am not a expert in this field by any means and there may be someone else that can give you a better answer but I will provide some insight from experience. When this happens it is usually do to the television going into protection mode, this is to let you know something is wrong inside the T.V., it does this to prevent any further damage to the T.V.. I do not know but if it is still under warranty you should read your warranty paperwork and contact whoever it tells you to, if it;s not then you should contact your nearest T.V. repair shop.
hope this helps
Carl
Feb 07, 2008 | Televison & Video
Ps36109 36"
sir if you do not want to throw it problem is simple. When i turn it on it just makes a clicking noise but no picture. the problem is due to tuner section of your tv or cable wire is old or not connected properly. regards
Sep 12, 2007 | Proscan PS36109 36" TV
the power supply is shuting off it self becouse a short, you may have to take to a repair shop, becouse there are nothing that regular people can do, is a job for a tech..good luck
Aug 09, 2006 | Proscan PS36109 36" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
