Locked comp - Computers & Internet
  • mike mastandrea Mar 11, 2008
    TERRY
    DONT HAVE PASSWORD TO LOG ON
    Sergeant:
  • 349 Answers
If you take the battery out of the motherboard for say 30 minutes this may unlock it,
you are very short on detail, i could have just said "unlock comp" LOL
good luck
Terry
Posted on Mar 11, 2008
  • terry Mar 11, 2008
    if you expect others to take the time to help you ,you need to give more info to your problems,how can an answer be inappropriate given the level of detail provided by you
    cheers
    Terry
    ok then try my suggestion ,remove battery, it usualy works, sometimes it need a long time out others not so long.
    i presume you have tried hitting esc key or enter key,this also works at times,but the battery is the best bet
    cheers
    Terry
A/c comp.won't kick on tryed to jump pressure switch still nothing fuse is good 1989 Chevy 5.7 comp.is new
There is also a relay to check. If relay is ok, the compressor clutch or wiring to it may be faulty
Jun 07, 2015 | Chevrolet Cars & Trucks
My dash reads refrigeration low/ no ac. My mechanic added 2 pounds of freon and installed a new relay switch. The ac still will not come on and the compressor still will not turn. Please help!
the compressor may be locked up, make sure that you are getting power and ground to the plug on the comp. and if you are not then the problem may be in the high or low preassure switch, if ther is + and grount then try running a jumper wirefrom the comp. to a ground and one from the comp to the pos. side of the batt. and see if the clutch kicks in and out if it does then run the engine and run the same test and you will be able to tell very fast if the comp. locked up. more often then not it will be a preassure switch
May 13, 2011 | 1998 Cadillac DeVille
My laptop presario cq41's monitor is not displaying anything. but caps lock key and scroll lock is blinking automatically
Try moving the mouse or push the power button. If it doesn't work try turning off the comp., then unplug the ac adapter and remove the battery. Hold the on button for 10 seconds without the powersource. The put the battery back in and the ac adapter and try turning on the comp. again.
Mar 18, 2011 | Computers & Internet
EATC Fuse/AC Compressor
yes clutch is replaceable to check if comp is locked turn clutch itsefl not pulley if unmovable by hand replaced comp
Jun 29, 2009 | 1999 Lincoln Town Car
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
Kenmore side by side refrigerator (model 50542001)
THE SUSPECT YOUR COMP HAS LOCKED UP AND IS TRIPPING THE BREAKER,IF YOU HAVE A METER YOU CAN CHECK THE AMP DRAW,LOOK ON THE COMP. AND YOU WILL SEE THE LRA DRAW-MIKE
Mar 01, 2009 | Kenmore Refrigerators
Ipod won't sync to Itunes
give it a soft reset if this is not solve the prob
give it a firmware upgrade
u can find the upgrade tool and the F/W
on ur website support area
plaese rate this post!!
Aug 18, 2008 | Apple iPod nano
Compal DL71 ... security issue?
Nope, that is for a Kensington lock like these http://us.kensington.com/html/1434.html . Re: power - try it with the battery out - test the adapter to see if it is actually providing power (get a $10 multi-meter to test - should be 19v DC). AC adapters are available all over the web as are batteries.
Jul 16, 2008 | ASI COMPAL DL71 15.4 WXGA 915GM SONOMA...
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
