Question about Akai PT46DL10 46" HDTV-Ready Television
J lamp for akaipt46dl10
Got the right lamp but after about a minute
  • Tuncha May 06, 2008
    When I turn the TV on what Iget it a grey scale broken apart picture. After a while the picture goes out competely and what I get will be just a sound. afer several trials thecolor comes.
    What is my problem?
My remont not respond
Posted on Apr 11, 2008
    Problem Solver:
Were did you get you new J lamp?
Posted on Mar 12, 2008
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
AKAI Rear Projection TV Model AKAIPT46DL10 Will not turn on. The power went out during this last storm and when it came back on the TV would not power on.
When you say that the tv would not power on do you mean that even the LED at the front does not come on? Please provide this info so that I can help you with your problem.
Sai.
Aug 29, 2011 | Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
How to replace lamp
hi,
1.Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
turning the power off.)
2.Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it.
Take the new lamp out of the box.
3.Remove the Front Panel Cover.
4.Pull out the lamp.
Loosen the screw on the lamp cover with a coin or similar object to
remove it, slide the knob to left, and then pull out the lamp cover.
Loosen the screw that holds the lamp, then pull out the lamp.
5.Reattach the lamp.
Place back the new lamp and tighten the screw.
Replace the lamp cover, slide the knob to right till the up arrow down arrow mark
matches, and then tighten the screw.
6.Reattach the Front Panel Cover securely.
ok
Feb 26, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
My TV turned off after a power surge, now a red light over "lamp" is constantly on. When we push the reset button, we can hear sound and then the tv turns itself off after a minute
If the Lamp light is steady, the lamp has failed and must be replaced. The TV will not work until the lamp is replaced (and the lamp cover is properly attached). Call (800) 553-7278 to get a replacement lamp from the manufacturer. Order lamp part number 915P028010. Once you have the replacement lamp, make sure that the TV is off for at least 30 minutes before replacing. Avoid touching the lamp glass - it will shorten the lamp life. Unplug the TV and use a Phillips screw driver to remove the lamp cover from the back of the TV (2 screws hold it on the right hand side) . Loosen the two screws that hold the lamp cartridge (one on the bottom left corner and one of the top right corner). These screws will not come completely out. Grasp the handle and pull the lamp cartridge out straight towards you. Place the new lamp cartridge completely into the opening then tighten the two screws that hold the cartridge. Replace the cover and screw it back into place.
If the lamp cartridge or cover are not properly secured, the TV will not come on. (There is a safety interlock).
I hope this helps.
(the lamp should last at least a year; if not, contact the manufacturer for a warranty repair.)
Oct 10, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
Put a new lamp in my tv now green light blinks 10 times
First thing to do is to make sure the lamp door switch is closing right, also, unplug the set for two minutes....and and then if it still does not fire...--did you use a TOSHIBA lamp?? DO NOT use a "generic" lamp in these sets--they will NOT work--I have seen a LOT of them that would not fire at ALL--right out of the box!! Many brands youc an, and should, use a generic lamp, but not Toshiba, they are VERY specific to their lamp needs.
Oct 09, 2009 | Toshiba 50H82 50" Rear Projection...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
LAMP goes off after few minutes
1-check the counter reading of lamp to see if it is in the right age of lamp or not.if it is in right age the problem still in power unit or in ballast.
Feb 14, 2008 | LG RD-JT91 Multimedia Projector
Akai PT46DL10 46" HDTV-Ready Television Logo
89 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
