Question about Samsung HP-R4272 42 in. Plasma HDTV
Crazy (red) disturbances in image
Hi- I have had a Samsung HP-R4272 42" plasma for about 3 years now, so it's way out of warranty. A few months ago, it bagan to flicker for the first few minutes it was on, and here and there there would be a few pixels that would misbehave (light up bright with one color), but again, only for a few minutes, and never in the same spots.
Two days ago it started to show a really bad image, with these bands here and there under the whole image, and this mess of red distortion all over the screen. I have seen what i thought were other colors in the distortion, but really it almost all red - like spray or bleed. Changing inputs doesn't seem to make a diff. I can see disturbance through the black when there is no feed. I generally use the RBG component, but the vid input on the side gives the same effect. I am attaching a pic or two I tried to take. I am hoping this is some video board of some sort that failed. Anyone have any ideas or pointers? I would be eternally grateful.
  • innate Mar 11, 2008
    Sorry - don't know what an IC is. Can i replace it myself if i contact samsung for the part? I have no problem opening and repairing computers and electronics, sans solder.
    Excellent - thanks much.
I have a very similar problem. My HP-4272 is about 3.5 years old. Started off with the bottom half going black for a couple of seconds. Then the top would flicker. Now I get the following picture... Not sure if I need to replace boards (Y-buffer lower, upper, and/or Y Main Board)? or if something just needs to be "adjusted"...
Posted on Mar 24, 2009
Ysus board need to be adjust. There is a pot ( adjustable resister) on the ysus board that needs adjusting.
Posted on Jan 26, 2009
  • bimbajan Jan 26, 2009
    ysus board need to be adjust. There is a pot ( adjustable resister) on the ysus board that needs adjusting.
Pals, I have almost the same problem but mine is in the middle of the screen and is thinner than that. Whats the cause of it??? can it be repair and isnt too expensive??(mine is a samsung PL-42P5H, 2 years with ps3 hooked)
Posted on Jan 15, 2009
  • 4,889 Answers
The red convergence IC is signing off.. You will need to get it replaced!
Posted on Mar 11, 2008
  • 1 more comment
  • eagle338
    eagle338 Mar 11, 2008
    No its not user servicable.. i would advice that you take the assistance of a tech.. the IC costs around 15$ even including labor it shouldn't run you more than 50-75$. Hence i strongly advice to give a call to samsung... dont risk damaging your set..!
    Regards,
    Sai.
  • CoppellTVRepair.com Dec 19, 2010
    First of all, there is no such a thing as "red convergence IC" in plasma TVs. I'd be curious where did you come up with that stuff from.
    Second, the problem is very common and very clearly buffer boards problem. No adustments will help it, only replacement of the buffers and it better be done before they short.
    Third, it is correct this is not serviceable at component level (it is too expensive), but the prices quoted are, unfortunately, not realisitc...if only because of the first reason I mentioned. If that was a DLP TV then yes, they would make sense.
    For more details see http://blog.coppelltvrepair.com/2010/10/...
  • eagle338
    eagle338 Dec 20, 2010
    That was posted a long time ago and I di not see the model number before posting.. I realized my mistake but there is no way to remove posts here. You do not find mistakes like these in my later posts. I appreciate you taking time to point fingers at someone else!
Samsung 50 " plasma. PN50A450P1DXZA my screen went out a few days ago. the red power light when the tv is off blinks a lot when i try to turn it on. after a min or so the white light under the logo turns...
I have the same problem. No video just audio.
No on screen display visible either (volume, channel labels) nothing.
Samsung tried to repair this under warranty TWICE within 2 months. Second time they replaced circuit board and it worked for another 8 months. So I paid $1.500 for a TV that died again after 1,5 year - this is ridiculous.
I have no idea what the reason might be and I wont try to fix this since samsung tech could not fix it without replacing circuit board.
Jul 21, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Hi my name is amit sharma currently residing in melbourne. i purchased samsung plasma "50" inches. i purchased it 3 months ago.i had to borrow money to do this. when i bought this plasma i was...
Look in your owners manual and contact Samsung and complain about the Repairs. They can't do anything about the promotion deal, but they should check into the repair issue for you. Especially if the Company servicing the TV is an Authorised Samsung Center.
Hope that helps...
Geno
Apr 04, 2008 | Televison & Video
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Open Questions:
See all Samsung HP-R4272 42 in. Plasma HDTV Questions
Samsung HP-R4272 42 in. Plasma HDTV Logo
1,322 people viewed this question
Henry  Thomas
Henry Thomas
