Question about Microwave Ovens
Kenmore microwave ..721.62642200
Night lights on microwave wont burn,replaced both bulbs. Both were blown,have not checked anything yet.Possible solution? Can I pull apart with out taking off wall?Everything else works fine.
  • burnthills Nov 26, 2008
    Night lights will not go on.
  • Anonymous Mar 15, 2014
    Microwave will only runwhen door is lifted or pulled out a fraction
  • Microwave Ovens Master
  • 9,086 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can send it without removing the oven from the wall.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 11, 2008
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Posted on Nov 26, 2007
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
Light doesn't go off and microwave doesn't work
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 14, 2013 | Sharp R305KS Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
The lights wont come on
test this and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2aavxew74
Jul 30, 2013 | Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Kenmore 63682300 Bulb blew now lights won't turn off
See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave down-lights not working, model 721.62643200 1000W
This is a very common problem we repair. The main causes are when the filaments short the power supply or when a bulb is removed or installed with the oven plugged in. We repair these control panels for $32.50 nationwide. For more information about our repair service, plus our critical safety and disassembly info, see our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 31, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
552 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
