2002 Ford F250 Super Duty SuperCab Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 F-250 door not register that it closed - 2002 Ford F250 Super Duty SuperCab
Aceppdug
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Mar 20, 2010
Aceppdug
Expert
Level 2:
Scholar:
Answers
75
Questions
0
Helped
53377
Points
162
The sensor is inside the door and is part of the latch to close the door. It has either come loose or is broke and you will need to replace the actual latch inside the door that keeps the door closed.
1helpful
HOW DO I PROGRAM A REMOTE CONTROL FOR A 1998 TOYOTA CELICA SRX
I found that the 97-99 ST204 Celica uses the same Alpine alarm used by the BMW E23 so I tried the instructions for that and it worked, so if anybody else needs this info here it is
My remote is P/N 08191-00900
1. Close all doors, trunk, and hood.
2. The security system must be in "disarm" mode. The key must be removed from the ignition key slot.
Enter Code-Learning Mode
3. Open the trunk and leave it open.
4. Open the driver's door and sit in the driver's seat.
5. Close the driver's door.
6. Cycle the ignition switch five times between the "off" position and position 2 (ignition "ON", all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will "chirp" once, to indicate that the code-learning mode has been initiated.
DO NOT START THE ENGINE
The ignition switch cycling in step #6 must be performed within ten seconds.
The sequence in steps #1-6 must be performed within 45 seconds.
Registering/Delete ID Code(s)
7. Open driver's door, (remain seated in driver's seat)
8. Close driver's door.
Edit: an extra step is required here for the Celica- cycle the ignition key once more from off to ignition on then back to off
9. Press and release any button on the remote you wish to register into the system. The status LED will shut off momentarily to indicate that one ID code has been registered.
10. Repeat steps 7 through 9 to register the remaining three ID codes.
Exiting Code-Learning Mode
11. Open driver's door, and exit from vehicle, leaving the door opened.
12. Close trunk.
13. Close driver's door. The LED will turn off and the siren will "chirp" twice.
14. The initialization procedure is now completed, test all remotes to confirm operation
1helpful
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
1helpful
Hi, When closing the driver's side door, the door
The obvious choice is the cheapest. Somewhere in the door jamb is a small push button switch which either closes opens a circuit when the door is closed. That state is relayed to the computer which turns the interior lights and the door ajar system on or off . The switch generally either screws or snaps in. So as a first step I would get another switch and replace it. If it still does not work then I think the fault lies in the computer, however it is a VW and I have been wrong before.
2helpful
My 'Door Ajar' light is on along with the bells, but the doors are all shut and the interior light is not on
It is very likely that one of the door switches is faulty and doesn't register as closed when the door is actually closed.
Door latch
check the door jamb switch it would cause the light to stay on
1helpful
Recode a key 4 bmw 318i cenral locking
To carry out this procedure you need to have one working key and one key which requires programming. It may help sometimes to hold the key close to the rear view mirror as this is where the sensor is located in most models. 1. With both keys, get in the car and close all windows and doors. 2. Put working key into the ignition and turn to position 1 (the accessories should turn on) (try also position 2) 3. Turn the key back to position 0 and take the key out of the ignition. 4. Using the working key, hold down the unlock button, press the BMW logo (lock button) 3 times, and release the unlock button. Doors should lock and unlock. 5. With the new key, hold down the unlock button and press the BMW logo (lock button) 3 times and let go of the unlock button. Doors should lock and unlock and you're done!! If not working try the following PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation. If this doent work your alarm/central lock needs to be reset
4helpful
Programming a 1995 toyota avalon key fob
To program a remote... note that you must not delay more than 10 seconds between any of the operations.
Driver's door open, all other doors closed, key removed from the ignition switch.
Insert key into ignitions switch, then remove it.
Press LOCK then UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times.
close and re-open drivers door.
Press LOCK and UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times
Insert Key into ignition switch.
Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code while erasing the original codes. three times to check how many remote transmitters are currently registered, or 5 times to erase all registered codes.
Remove Key from ignition switch.
System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. It will lock and unlock one to four times slowly, to indicate the number of remote transmitters registered if you chose option 3.
Press and hold remote transmitter LOCK and UNLOCK buttons at the same time.
Press LOCK remote button for 1 second: System should now lock and unlock vehicle once to confirm, twice to indicate registration has failed.
NOTE: to exit programming mode, close drivers door or insert key in the ignition.
NOTE: a maximum of 4 remote transmitters can be programmed
Bmw e36 1996 318is
If ews2 alarm is fitted it need to be reset by computer. Any tampering will set it into protectction mode. Had similar problem. You can try the following but if it does not work get someonr with diagnostic computer. PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation.
Why does my key fob only open drivers door
this how a dealer does it:
DOOR CONTROL TRANSMITTER
REGISTRATION
1. REGISTRATION OF RECOGNITION CODE
HINT:
 The add mode is used to retain the already registered codes while registering a new recognition code.
This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously
registered code will be correspondingly erased in order, starting from the first registered code.
 The rewrite mode is used to erase all the previously registered codes and register only new recognition
codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
 The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function.
Use this mode when the transmitter is lost.
 The confirmation mode is to confirm how many recognition codes have already been registered before
an additional registration of a recognition code.
 All the following registration procedures must be performed in order continuously.
(a) The vehicle should be in the following conditions.
(1) The key is not inserted in the ignition key cylinder.
(2) Driver’s door is OPENED. (The other doors are CLOSED)
(3) Driver’s door is UNLOCKED.
(b) Perform the following operations to select the desired mode.
(1) Insert and remove the key from the ignition switch twice within 5 seconds.
(2) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
key into the ignition key cylinder and remove it.
(3) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
key into the ignition key cylinder and close the door.
(4) Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1
to 5 times to select a mode.(2 times for rewrite mode) Then remove the key from the ignition key cylinder.
(5) After selecting a mode, the integration relay automatically performs the power door
LOCK-UNLOCK operation within 3 seconds to inform the selected mode.
(c) Register the new recognition codes :
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and
UNLOCK switches on the transmitter switch simultaneously for 1.0 - 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0
seconds.
(2) Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation
will be automatically performed once if the registration of the recognition code of the transmitter is
completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of
recognition code has failed. Perform the registration procedure from the beginning once again.
(3) If the multiple transmitter to be registered, repeat step (c) within 40 seconds after the previous registration.
this is why the dealer charges for this
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
