Question about Samsung HCL5515W 55" Rear Projection Television
Green Tint in HDTV for the first few minutes.
When using an HD source in the Component 2 (1080i) input, the screen is very green tinted especially for the blacks on screen for about the first 10 minutes, then it clears up and the picture is normal. Any idea why this happens?
    Novelist:
    Champion:
  • 203 Answers
Possibly adjustments to the service menu could rectify this. Also, adjustments must be made to customer settings in menu for each input. In the past I have improved or solved this by making service adjustments, however, if you attempt this, please make sure you know what you are changing and make sure you are in 1080i mode. Service code (mute,1,8,2,power on)vol+ and vol- to select an item. Use mute and the menu to adjust. Use add to save the settings. Take your time. Hope this helps.
Posted on May 29, 2008
Red tint on the screen an picture
Make sure the signal cable for the input you are using is tight. Possibly try a different cable. Especially if you are using the Red Green Blue component cables. Make sure the issue is across all inputs. If so, try adjusting settings for tint. if that doesn't help you may need to replace the TV.
Apr 09, 2014 | Dynex DX-L32-10A 32" LCD HDTV
Green tint on tv
Is entire screen green or just tint range will not move?
Look at set with color off to zero and also try different inputs.
Advise me source of signal and how or where you are connected.
Jun 13, 2012 | Seiki SC221FS 22 Class LCD HDTV
Picture has a green tint no matter how much you try to adjust out the green or add red.
You are probably on component input RED GREEN BLUE and the red has come loose at either the back of the tv or the source. If it is not loose, try inputting it into another input source. If that doesn't fix it, try new cables.
Jan 27, 2011 | Sony KDS-50A2000 50" HDTV
All my channels have a green tint on them.
You have not provided any details about your system. What components are in your system? How they are connected? Etc.
Have you tried resetting the TV? Have you tried switching inputs around?
Nov 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Vizio flat screen has very red tint when using HDTV component cables
Ummm... i have the same problem and its EVERY type of cable that causes the red tint. its the tv itself. replacing all the darker colors with red. explain that?
Jun 11, 2008 | Televison & Video
Mitsubishi WS-65711 green tint only with DVD via Component
there should be a setting in the menu that you need to make sure is set to YpPbPr not RGB if set to RGB it will give you a green pic on the DTV Input.
Jan 03, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Samsung HCL5515W 55" Rear Projection Television Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
