Cisco & Lynksys befsr81 linksys router
I need to send these to somebody who can check them out.The cable company tells us that these units are not working.
  • Paul Needler
    Paul Needler May 11, 2010
    Hi.  Is it that you would like to send these units to one of us experts on FixYa?
    How do these units not function for you, and what tests did the cable company do to confirm their failure?
    Scholar:
  • 141 Answers
Connect a pc to port 2 on the befsr41. Push the reset button for 30 seconds, unplug the power for 10 seconds. Check pc ip address, it should be 192.168.1.xx. If that is the ip address, the router is working.
Posted on Mar 12, 2008
I cant install password to my lynksys router
You didn't supply the Model of Linksys, so try Linksys support for a user manual: http://homesupport.cisco.com/en-eu/support/linksys
Jan 11, 2013 | Computers & Internet
I NEED TO GET A USB WIRELESS ADAPTER FOR MY COMPUTER, THE MODEM IS A CISCO,ANY SUGGESTIONS WHICH ADAPTER TO GET?
I would try to stay with the cisco/lynksys brand if money is available for it.
Just be sure of what speed of router that you have prior to purchasing anything. It is a waste of money to purchase a better card than you have router. Examples are G, N150, N300.
If you have a N300 router and card you will be very pleased.
Jun 12, 2011 | Computers & Internet
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
I have Timewarner cable and can't set up a vpn so that a client can connect into my Lynksys vpn router. Is it possible that the firewall in the TW router is blocking a client or that maybe I need a static...
No you need not buy a static address... just forward these ports in linksys router...
50 both TCP and UDP 51 both TCP and UDP 500 both TCP and UDP 10000 both TCP and UDP 1723 both TCP and UDP 1701 both TCP and UDP
also disable firewall in linksys router....
May 10, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
No Wi-Fi access when we use an access point.
Its not that the router is windows comparable it is on and Operating system can access it .
You need to set up the router with your account info from the company that supplies your INTERNET access.
You need to have a physical connection to the router to set it up use a standard eithernet cable and go to the default address which it should be (192.168.0.1 or 192.168.1.1 ) either one of these is probility the default address and login in if it has never been changed should be ( user-admin password- admin or password )
hope it helps here is more info on how to set it up
http://setuprouter.com/router/linksys/befsr81/login.htm
Dale
Dec 29, 2017 | Linksys BEFSR81 Broadband Router with 8...
Missing The Power Adaptor for the Mod. BEFSR81B
HI Salvador, the specs for the power supply of the BEFSR81 are:
Voltage: 5V DC
Ampere: 3A
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 16, 2009 | Linksys EtherFast Cable/DSL Router
Internet connection
1st check your cable with the tester 2nd configure your router then the last configure your connection go to control panel then network connection then right click local area connectn then properties one click internet protocol tcp/ip then properties check obtain IP add automatically then obtain DNS then start to connect again
Mar 27, 2008 | Linksys BEFSR81 Broadband Router with 8...
BEFSR81 Server and BOOTP Packet Vulnerability
A flaw in the built-in DHCP server causes the routers to send BOOTP reply packets that contain sensitive information about traffic running through the devices as well as other random information about the router's configuration. New firmware to fix this issue is now available! See information on the Linksys site for upgrading to the new firmware.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
AOL Broadband Cable
The following routers are the only models that support the AOL Broadband Cable service. Note: All Linksys routers support AOL DSL connections due to the standard PPPoE login and authentication connection type used with that service. Please be sure to check the version number of your router (which can be found on the underside label). Only the specific models and versions listed here are supported by AOL Cable: * BEFW11S4 * BEFW11S4 v2, v3, and v3.2 * BEFSR41 * BEFSR41 v2 * BEFSR11 * BEFSRU31 * BEFSR81 * BEFSR81 v2 * HPRO200 (Available from AOL only at this time) You must Enable the "AOL Parental Controls" option located in the Security tab of the web-based Setup utility pages of these routers in order to get a connection using AOL Cable. You may access the utility by visiting http://192.168.1.1 in a web browser and by logging in using the router's password (by default, the password is admin).
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
