Question about Superstar SS-121 120-Channels Base CB Radio
Superstar 121 ranger radio
How do i increase the modulation.
  • hanksadiecor Dec 21, 2010
    trying to figure out how to wire a **** for a superstar 121 cb radio
Make sure your SWR is as low as possible. you might invest in a modulation meter as well. the person that posted before me is correct, a "power" mic could help but the best way and most effective way is low SWRs.
Posted on Mar 15, 2008
  • 46 Answers
Hello...the best way without making internal adjustments...is to use an amplifier microphone...maybe a turner style mike hand or base...there is just a connector soldeing job and is usally an instruction for what pins to connect for your radio...it is often no adjustment internally in your radio that is good becauie it can give the result of splatter and over modulation...good luck Ron
Posted on Mar 11, 2008
  • skeletor68 Mar 24, 2011
    cut tr 32 you will increase the modulation
How do I hook up a amp to a Superstar 121 cb radio
first if must be adjusted for deadkey to be lowered down from 1-4watts as not to hurt the amplifier, then connect a small jumper to the amp, run heavy gauge wires to a good power source hopefully the battery.. just use a relay to switch on/off w/key/stereo circuit to turn main power off the the amp. if need too. Also the SWR's must be low have them checked. Free @ any Good Radio Shop.
Mar 10, 2011 | Superstar SS-121 120-Channels Base CB...
Superstar 121 has only 50% mod. what needs to be cut to get 100% or more
Some people say cut off or jump the mod regulator on the circuit board. It would be better to get the specs on the circuit and using a small to screw driver (with power off) to turn it up counter clockwise all the way. It is factory set at 50 to 90% modulation. I would not turn it up all the way unless the radio has a mic power output adjustment on the panel. This way if you go "over mod" you can cut back the power. Many "S" meters will also show modulation so you can see if it is too high (into the red). Check for response to modulation before starting to see if it reads modulation. Afterwords to check, key the mic without making any sounds and see where the meter sits. Then whistle into the mic to see the meter moves up. If nothing happens it could be: 1) the "S" meter does not show modulation, or 2) you turned the adjustment in the wrong direction. If no one answers your calls it would be #2.
Feb 28, 2011 | Superstar SS-121 120-Channels Base CB...
How do i increase the power in my super star 121 radio?
To increase modulation you want to change R142 and R174 to 10 K Ohms. You
Modulation boost: Change R142 and R174 to 10k ohms.You can clip d80 for talkback. Now for the power, look in the radio towards the back. You see the pot with the ferrite in it right behind c144 - it might have some glue in it. Gently scrape that glue out of there with a plastic screwdriver. Now unscrew that ferrite clear out. Those will be your main adjustments you can do without a scope.
Jan 26, 2011 | Superstar Radio Communications
No talkback
Remove D80 to achieve talkback, or put on switch. - www.killercatradio.com
Aug 11, 2010 | Superstar SS-121 120-Channels Base CB...
I want to convert a ranger superstar ss39 to a cb radio
I need to know a superstar what? If you want call me @ 904-845-3847 mel
Mar 17, 2010 | Radio Communications
How do i get more mod out of superstar 121 cb
A super star will only put out around 28 to 30 watts, any more you need a linear, you could have you r swr checked to make sure your antenna is good, any good antenna should talk around 10 miles
Nov 22, 2009 | Superstar SS-121 120-Channels Base CB...
Superstar 121 with astatic power mic and texas star dx 500 power..when I key up to talk they say I sound like I'm a ways from the mic, but I have a loud roger beep...any ideas....mic?...
try a stock mike or a noise canceling one. Hard to run power on top of power. And see what your radio is dead keying into the radio...usally with a 500 it can take up to a 6 watt dead key.
Nov 10, 2009 | Superstar SS-121 120-Channels Base CB...
Radio Communications Logo
276 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
