Question about Canon PIXMA MP600 all-In-One InkJet Printer
Document won't print (USB001)
I am trying to print 4" X 6" cards, a size I printed yesterday without a problem. Now I get a message that the printer cannot print the selected paper size. It tells me to print from the rear tray rather than the cassette, but it doesn't work from there either. I get the same message. The size is a standard size I can select on the set up page.
  • 27 Answers
SOURCE: How set Printer to Autoselect Tray
This will most likely be the in the menu on the printer. Refer to the users manual and how to access those setting.
Posted on Jan 29, 2007
  • 167 Answers
SOURCE: printing from wrong tray
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Posted on Jan 24, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: Stopping Auto Tray Selection
If you use different print materials of the same size in the trays, each tray with a different print material should have a unique paper type setting to prevent the printer from linking the trays together and mistakenly printing on the wrong paper.
From the printer's operator panel, choose the paper menu, then paper type, then select the source (ie, tray) that you want to change.
For example, if you have plain paper in tray 1 and preprinted paper in tray 2 and both are set up where size = A4 and type = Plain paper then when Tray 1 runs out it will automatically feed from Tray 2. To prevent this from happening you should change Tray 2 type = Letterhead. In this way, the printer knows that the two media types aren't identical and won't pull from that tray unless you specifically tell it to.
Posted on Mar 10, 2009
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Hp officejet 7000 won't print 6.5 x 10 paper size
Officejet 8620 printed about 400 for me in 16 months then stopped. A few weeks prior to the error msg. that the paper in the tray did not match my document settings another message said it did not recognize any paper in tray including letter size despite there being about 100 sheets. I c alled HP two different days, tried documents on a brand new computer, created a new document. Took two hours total and $20 to be told the printer did not support this paper size. I called them prior to purchase and told them my needs and was told it would accommodate the size. My local techie and I both think the sensors have gone bad in under 2 years as I had been able to print my cards with no issue about 400 times. I called Epson three different times and each tech support person says Epsons can accommodate this.
Aug 08, 2012 | HP Officejet 7000 Wide Format Printer...
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
ME Feed C5
Jun 24, 2010 | HP LaserJet 4 plus Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Jul 29, 2008 | HP Officejet 6310 All-In-One InkJet...
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
293 people viewed this question
old marine
old marine
