Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune washer My neptune washer is not going in to spin mode to ring out the clothes?
  • 1 more comment
  • gleathem Mar 11, 2008
    My Mayatag neptune top load washer stops during the wash cycle....about the time it would go to the spin cycle. It doesn't take the all the way out, and it blinks nd on the display.
  • mimikins Mar 29, 2008
    My neptune XL FAV6800AWW will go through 2/3 of the cycle o.k. until it needs to spin in the last 12 min and it slowly spins, then the dc code comes up and there are a few inces of water in the bottom of the tub. Its approx 5 years old and this is my first problem and did not overfill the tub.
  • Anonymous Jun 01, 2008
    My washer seems to be stuck on low rinse (hang dry setting) and will not switch to any other setting, also it takes a couple of pushes to get the machine going sometimes. When it doesn't go it beeps at me and then I push it again and it goes.
    Problem Solver:
  • 14 Answers
I have a neighbor with a similar problem. The display shows 8 minutes remaining (quick mode/short wash) but the washer will not go to the spin cycle. The display goes back and forth from 8 to 7 and back to 8 mins remaining. The clothes are very wet but there is no water in the drum. The towel is dripping wet.
Posted on Sep 03, 2008
  • 96 Answers
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Posted on Mar 11, 2008
  • Abraham Holland Mar 11, 2008
    The error signal "nd" means no drain. Either the drain pump is not working or the drain line is clogged. Try disconnecting the drain hose and check for a clog. Then, when you reconnect the hose listen to see if the pump is working.
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
I want to place wet clothes in the washer and just spin them without washing them
sounds like you have a door lock problem, maybe the wax motor is not working properly of the spin switch is bad. You may have a problem with the motor controller also. Kind of hard to tell you how to trouble shoot on internet, unless you just want to replace parts till it works, call for service.
Apr 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Our washer is not draining all the way and has a dc code, befor going into spin. we can remove the clothes, ring then out,run the spin and it will drain then we can put the clothes back in and it will do...
From what you describe it sounds like a Clutch malfunction of your FAV6800A or FAV9800A. Always include your machine model number in the post.
If it's one of those models see this post Clutch Fix to DIY the fix.
D*ick
Aug 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a neptune MAH-1 washer, the door locked
if you remove the back console, youll be able to see the "machine controlboard". appro. ha;f way down and favoring the left side of circuit board youll notice a small blue relay cover(MAYBE 3/8"X1/2" in size. well just above that relay cover you see a resistor that will be physically burnt out( a real noticable burn ring around it) if this is the case you need to replace the board as well as the "wax motor" within the latch assy.
Jun 15, 2009 | Maytag Neptune Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
271 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
