Recovery of Acer Hard Drive
I am in the process of doing a full recovery on my Acer Laptop. However, when I get to the part when the recovery is complete and I am asked to insert the systems CD again it simply takes me right back through the whole process. What am I doing wrong. Dave.
  • dhearn Mar 11, 2008
    Thanks Terry. When I do that the original problem which prompted the hard drive recovery is still present. I get the following:
    Windows could not start because the following file is missing or corrupt: \windows\system32\config\system. Any ideas?
    Dave.
    I am using the recovery discs that came with the computer. I am assuming they are the o/s. Thanks for your help on this one. Dave.
    Sergeant:
  • 349 Answers
Try to reboot when it asks for the recovery disc at the end, without the disc in the drive.
good luck
Terry
Posted on Mar 11, 2008
  • terry Mar 11, 2008
    do you have the o/s disc or are you trying to recover off the hidden partition on the hard drive?
    The only other suggestion, i have know this to happen when the drive is about to die if you have a floppy drive in the pc use a boot disc with fdisk on it ,boot from it ,you may have to change the boot sequence in the bios ,when at the command prompt type "fdisk then delete the primary disk or what ever it is set up as, then set it up again,it will do a check of the drive and may fix some problems ,but if its on the way out you will need a new hard drive,
    it would be good if you had an old hard drive to try it out first.
    if the hard drive is fine then you will have to order a new set of disc from Acer.at a nominal cost
    my email is tkw2201@gmail.com
    let me know how you go
    good luck
    Terry
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
Acer 5334 stuck on e recovery management screen
By stuck do you mean that each time you boot the computer it goes to this screen? If this is the case then unfortunately this means something has happened to the installation of your operating system on your hard drive and in order to get Windows to load, you will need to perform this recovery. This could be caused by any sort of damage to the partition that the OS installation is on which could be caused by hard drive failure, corrupted data or physical disk damage.
I hope this helps.
Jun 27, 2011 | Computers & Internet
How do i reset my accer aspire 5336 laptop to factorydettings
This information can be found on the support page of Acer.com
http://acer.custhelp.com/app/answers/detail/a_id/2631
How do I reinstall the Operating System on my computer?
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form.
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Thanks for using FixYa.com
Apr 28, 2011 | Acer Computers & Internet
I need to restore my acer 5610z laptop back to factory settings
To restore my computer to its original settings without
recovery CDs.
Note: If your system is the multilingual version, the operating
system and language you choose when you first turn on the
system will be the only option for future recovery operations.
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST.
37
English
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press + at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 3 to 4 GB in a hidden partition
on your hard disk
Thanks for choosing Fixya
Mar 17, 2011 | Acer Aspire 5610 Notebook
I cant restore my acer laptop back to factory settings it keeps giving me process 14/29 erecovery all the time !my computer has restored !but the program erecovery stays in task bar and on screen !i do...
Take the battery off the computer and plug it in using the ac adapter. press and hold the 0 key while holding down the power button. Should take you to the recovery screen, follow the props there.
Mar 05, 2011 | Acer Aspire 5535-5050 Notebook
How do i reset my laptop back to factory settings
The disc that you should have received with the laptop should give you this option. Just put it in and reboot and it will bring you to a menu with a few different recovery options to choose from.
Feb 28, 2011 | Acer Aspire 5500 5570-2609 Laptop
I want to reset my laptop to it's factory settings.
hello.push DEL or F2 immediately after powering on.
Than your are in the bios
push F5 confirm
push F10 confirm
restart the pc
try recovery again
Jun 30, 2010 | Acer Aspire One PC Notebook
My aspire notebook want to reformat but theres no cd or dvd drive on it
It should be a recovery partition on your hard disk. Try this :
Turn on your laptop. On boot, press <F2> to enter BIOS. To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled. Save and reboot. While the Acer logo is shown, press <Alt> + <F10> at the same time to enter the recovery process. Refer to the onscreen instructions to perform system recovery.
You could miss this process, if it is so try again.
If there is no recovery partition on the hard drive you need a CD revovery kit for your model. Contact Acer support team and ask for it. If you are lucky you will get one for free or you will pay a very affordable price (10-20$). If not, try to find a friend that has the same version of Windows as yours and you can use it with your activation key (you find it on a label on the bottom of the laptop).Also, you have to purchase an external (USB) optical drive (CDROM/DVDROM)
Oct 09, 2009 | Acer Aspire One PC Notebook
No operating system
Contact Acer and have them send you a new recovery disk. Be sure to have your computers paperwork handy when you talk to them. The problem" operating system could not be found" could be software or hardware related. I'd try to load the OS using the recovery disk first and see if that fixes the problem... mpawlak
Oct 06, 2009 | Acer Aspire 9300 Notebook
Have a travel mate 2423wxci preinstalled windows xp home edition. Have formated the hard drive but can't find the recovery disk. How do I get one?
Did you format the whole drive?
If you didn't fully format the drive then the Recovery Partition could still be intact.
Start the laptop up and at the splash screen keep tapping F10 or ALT+F10 and if the Recovery Partition is intact the laptop will start the recovery process, if you get a message say BOOT EXECUTE/NO then the partition is not there.
You have 2 options now:
  1. Call Acer and get a set of recovery disc's, will cost approx between £20-60 for a set of discs.
  2. Buy a copy of XP home edition and then download all the drivers for your hardware.
Thanks
Sep 05, 2009 | Acer Computers & Internet
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
