Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Humming I have a 55" rear projection and after watching for about 2 minutes it starts to hum real bad!!! I have no Idea what the problem is????
I had the same problem and all I did was take the back off and vacuumed all the dust out of it and it hasn't done it since.
Posted on Apr 10, 2008
2004 gmc envoy 106000 miles, rear humming noise at about 50 to 55 mph. brake work was done about 4000 miles prior.
here is a list of things that cause humming from the rear busted belt on the tire, bad bearing/s on the axle/s, planetary gears, dry rear end ring and pinion gear
Jan 20, 2010 | 2004 GMC Envoy
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Rca p52960 wont turn on
Humming or singing can be Shorted horiz out transistor
and bad fly back transformer........need service # off back of
set for part #'s.........T.
May 12, 2008 | RCA P52960 52" Rear Projection Television
Humming
Gud day..may be there is a lose of connections or corroded solder...check also for connectors and thigthen it...you said if you hit at the back it will back to normal..may be there is a loose connections..ty
Mar 08, 2008 | Zenith R40W46 40" Rear Projection...
Audio issue
Unplug the rca cables from the TV to the stereo does the hum go away?
                     JR57Gard
Oct 23, 2007 | Samsung HCJ552W 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
