Question about Maytag Neptune FAV6800AW Top Load Washer
Leaking from main shaft
Maytag top loader
I have a leak from the main shaft coming into the drum from the bottom. How do I remove the drum to check the seals?
    Genius:
  • 3,587 Answers
You need to take the panels off, and then detach the drum. not easy..as long as your in that deep, might as well replace the seals.
Posted on Mar 11, 2008
Anybody have an issue with drum leaking on a Maytag Centennial washing machine?
top loader leaking ?? this is unusual !! I did have a top loader leak once (not maytag) that the operator overloaded it and allowed it to try and spin dry , it shook unattended so bad it shook loose the hose connections from drum to pump , id suggest checking exactly were it leaks from with a flashlight looking at machine with back off ,while its running , use only your eyes !! for safety !
Oct 20, 2016 | Maytag Washing Machines
Leaking washing machine
Need more information. What type of leak (fast, slow, seep, etc.), when does it leak (when it is filling, draining, all the time, or don't know), and where is the leak coming from? If water runs out as fast as it is filling, you may have a drain hose that is ruptured or has disconnected. If it is a very slow leak, you may have a connection that is working loose. Or, it could be as serious as a hole in the outer drum. Is this a top loader or a front loader washing machine?
Apr 10, 2014 | Maytag Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
My Maytag top loader leaks at the bottom of the bucket. I took off the front cover and should see that the wahser at the top of the shaft is leaking. Is this an easy fix?
not easy, unit must be stripped to allow access to bottom seals and bearing/s. Special tools needed and a goog knowlege of the wiring.
Sep 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Maytag washer leaks only during spin cycle
pull off the front cover and look for origin of the leak,if its a top loader, likely source is the main tub seal ( youll see leakin from center shaft while in spin)
May 01, 2008 | Washing Machines
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
