Question about GE WBSR3140DW Top Load Washer
Willnot spin all the water out
The washer spins but leaves about 3 inches of water in the bottom , it spins but very slow.
  • Pappy22 Mar 13, 2008
    This was a very helpful , I haven't had a chance to try this yet but will let you know how it works! Thank you Pappy22
    President:
  • 1,294 Answers
Not too familiar with this machine. First clean out your filter, refer to manual. Plug off the wall socket. Then try to disconnect hose from under tub to examine for any block. Finally check the pump; the fact that it spins slow is because of clogging.
Posted on Mar 11, 2008
  • prem mathew Mar 11, 2008
    If not helped click 'thanks for trying', your prob will be back for someone else to try.
Washer agitates but will not spin
Spin clutch has water getting on it ( replace)the unit.
Jul 19, 2014 | Whirlpool Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
My washer has water in the bottom of it. I pressed drain and spin it did then it filled back up with water.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 01, 2010 | Kenmore Washing Machines
Will not spin out water
Sure its not pump you can hear? your motor carbon brushes may need replacing
Feb 11, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
The water is not being pumped out of my kenmore front loader washeer machine
Unplug the washer from AC
Open the bottom access panel (3 screws on bottom lip)
open the large filter in center,
be ready for a lot of water, mops and rags ready. water vac is really handy .
Clean all the debris you find in the filter, reach in an spin the little propeller and make sure it spins freely.
pour in a cup of water inside the tub does it drain down freely.
reassemble and test.
front access panel has a switch so it has to be closed back.
Jan 26, 2008 | Kenmore 43142 Front Load Washer
My direct drive washer spins slow
Always rule out first: Unsorted, too big or off balance load, too high or restricted drain, oversudsing or water not draining completely out before going into spin. Otherwise the brake could be not releasing fully or the clutch lining is worn. Pull the basket and transmission and check the basket drive.
Nov 11, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
GE WBSR3140DW Top Load Washer Logo
134 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
