Same problem with mine
Did you ever fix your problem with your computer? mine is doing the same thing. it get so hot that i cant even touch it.help
  • 2 more comments
  • fmarc19 Feb 05, 2009
    the fan is not working on thie notebook. how do you get the computer open in order to change fan. I have removed all screws but it seem stuck at the hinge end of the computer bottom, near the battery compartment
  • aawen Feb 10, 2009
    same problem to me lately, finally decide to order a new one, but neither acer itself or mundocorp.com (acer referal) has the parts in stock, wasting time on waiting phone all day today, frustrated.
  • Anonymous Apr 23, 2009
    The back will not unhinge.
  • kalbutt May 11, 2010
    Hi, The only thing I did which seems to have helped was took the fan completely apart and cleaned out all the **** that had built up inside. touch wood it has not yet shut down since. that's all I can suggest im affaid.
Once, I had the same problem, and i solved it buy cleaning my fan!
You need to unscrew the 6 screw under your laptop and clean the fan and espescially the part between the fan and the laptop itself.(there is allways a lot of dust).
Posted on May 21, 2008
  • 3 Answers
1. Take off the silver plastic strip (where the power button is) and the keyboard then unscrew the fan.
2. Remove it and clean it using a paper towel and anti-static foam.
3. Gently scrape out the dust build up from inside the fan cubby.
Make sure all is dry and reconnect the fan, keyboard and strip.
Should be a lot quieter now as air will pass through as it should.
Posted on May 13, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
I think your fan is not working
and dont kept on metal
Posted on Mar 27, 2008
MY TOUCH SCREEN ZTE GROOVE MUSIC DOES EVERYTHING BUT THE SCREEN WONT WORK HOW DO I FIX IT
Mine Does The Same Thing I Am Trying Everything Letting Get Air And All It Still Wont Work I Really Need this Phone And My Screen in Black CANT SEE ANYTHING its a ZTE GROOVE PHONE
Jan 18, 2013 | Cricket Wireless Cricket - Zte X501 Groove...
My samsung tocco lite touch screen wont work only the buttons and the camera button work i try and touch something on the screen and if it is at the top of the screen it will move if i touch by the bottom...
same thing happen's to mine, and i'v only had mine for two months :O aha, although i believe it's 'cause i got the screen wet, i mean it's happened before but, usually worked but, this time i think that the water dissolved into the phone making the touch screen not work, mine's still not fixed but, trying taking the phone apart and re-building it. That might help. Kayleigh xx
Jan 15, 2011 | Cell Phones
Why is the screen on my samsung tocco ultra frozen
turn it off and then on again, it fixed mine. good luck
Mar 06, 2010 | Samsung S8300 Ultra Touch platinium-red...
MY ipod touch has black dots all over the front and the touch screen doesnt work but the menu button does work and it turns on but i cant unlock it after i turn it on... I tried turning it off but since...
If you have black dots one of two things is broken
  1. The Video Controller is broken
  2. The LCD is broken
If you cant use the touch then the issue is a broken or disconnected touch panel (The touch and LCD are two separate components)
This is easily fixed for about $100. I replaced mine after a fatal fall shattered my front glass. and components.
If you are not tech savvy, call Apple they can fix it, but if your not covered by warranty then it'll cost you A LOT!
Aug 21, 2009 | Apple iPod touch
My wireless is not working even though it says the
This seems to be a normal issue with this Acer product. I had the same thing happen after only using mine approximately 25 times. While if you touch the switch it does say enabled on the monitor, it doesn't actually stay engaged. I have now done everything for 3 days as per Acer customer support online and I am awaiting them to offer that I ship the thing back to them so they can fix it or better yet replace it.
Aug 16, 2009 | Acer Computers & Internet
IPhone touch screen not working
I have the same exact problem. I dropped mine, and it landed half on concrete, half on a piece of foam board, and when I got to shut mine off, it will slide to power off, but will not slide to do anything else. Everything works perfectly fine, people calling me, texting me, nothing is broken or cracked, I can't even unlock mine, it's stuck and it's making me very upset! I want an answer as to what I can do and or can't do.
Jan 28, 2009 | Apple iPhone Smartphone
My Zen Touch Is Froze Help Please
Hello Karim... If you had the Zen Touch 20 Gb like I just have right now, try to reset it. Here's how: Set the POWER/ LOCK SWITCH to the left, so the player is locked (make sure it was on). You can see a small hole in the leftmost side, insert a hair pin or a thin wire to the slot and push gently (be sure it is the hole in the left side, the hole in the right is the microphone). After you'd done that, it would reset. Turn it on again, and hope that solve your problem. Another thing to do is to connect your player to a computer and browse the file. Don't do anything, just open browse the files. Then after awhile, plug it off from the computer... I haven't tried this, but this one is posted on one of the thread, and solved the unresponsive touch pad or keys.
Aug 20, 2007 | Creative Labs Zen Touch MP3 Player
Computers & Internet Logo
1,127 people viewed this question
David Payne
David Payne
